o2 sensor nightmare
Old Jun 5, 2013 | 03:49 PM
9uantum's Avatar
o2 sensor nightmare
I have a 2000 Maxima Nissan GLE I've been through two different sensors trying to figure out what the code P0430 for a "catalyst efficiency bank #2" is calling for.. a little help please ?
the last part I tried was a Denso 234-4270 Oxygen Sensor & my mechanic said it didn't even fit the car at all
Old Jun 5, 2013 | 04:02 PM
rebelhell's Avatar
Is your Max Cali or Fed spec? (Does it have 3 or 4 O2 sensors?)
Here is the diagram and parts from Courtesy Parts...
http://www.courtesyparts.com/maxima-...1988_1992.html
Could also be a bad catalytic converter.
Old Jun 5, 2013 | 09:21 PM
TravisCadello's Avatar
Hey that's awesome ^^^^ Thanks.
Old Jun 6, 2013 | 09:05 AM
9uantum's Avatar
how do i find out the number of sensors i have outside of asking my mechanic?
Old Jun 6, 2013 | 10:00 AM
Amerikaner83's Avatar
look under the car from the driver's side door...between the front and rear seat area you will see your main catalytic converter. If you see a little wire sticking out behind it, that's your one downstream O2 sensor which means you have a FED spec
TL/DR: Wire under = FED no wire=CALI
My guess is you have Cali spec, since both banks are being monitored...Fed spec doesn't monitor each bank separately.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
