Suspension issues
Suspension issues
its a 2003 se ,installed are new shocks,lowering springs,control arms,sway bar endlinks,alignment done twice.the issue im having is that there is a lot of play in steering wheel especially when i hit a bump it wobbles left and right and is very erratic,its weird because itd rives straight until i hit a bump or any road imperfection and when i am braking its seems to drag to one side.Any help will be appreciated
Jack up the front (lug nuts still tight) so the front wheels are off the ground. Then place your hands on the left and right side of the tire/wheel and push it back and forth like you are trying to manually turn the wheels left and right. If there is a bad tie rod you will definitely notice the play. It should be a tight system.
Mar 12, 2020 12:06 AM
mikeg75
Nov 30, 2015 05:12 PM
Violator
Sep 9, 2015 10:14 AM
