The Knock Sensor
Old Jun 30, 2013 | 08:49 PM
Kevin Ellis's Avatar
The Knock Sensor
Where is located and from a scale thru 1-10 how difficult is it DIY?
And what else is needed to complete this job
Old Jun 30, 2013 | 09:36 PM
tosheto's Avatar
It is not that hard. There are few write-ups on here. Just look for them.
Old Jun 30, 2013 | 10:04 PM
cjandura's Avatar
On the DS of the engine right under the intake manifold use 1/4" ratchet 2 8" extensions and a 14mm low profile swivel socket
Sent from my iPhone using MaximaOrg
Old Jul 1, 2013 | 02:00 PM
TunerMaxima3000's Avatar
It can be done without pulling the intake manifold, but it's tricky. Above is how to do it without pulling the manifold.
Old Jul 1, 2013 | 02:12 PM
Child_uv_KoRn's Avatar
Bad *** Newb
If you have small hands, then you can get them in there.
Be careful after you take the bolt loose! I dropped it and it fell into a crevice. I just said F it and simmed it lol
Old Jul 1, 2013 | 02:39 PM
NmexMAX's Avatar
dot dot dot ...
In order to do it right, you should remove the IM so you can apply proper torque to the new sensor. With that being said, it can still be done without removing the IM.
SO what's the problem, you get a code for a KS? Crappy MPG, low on power?
Old Jul 1, 2013 | 02:42 PM
cjandura's Avatar
Well that just good Mr. I can change my upper in 3.28 minutes with a fisher price rubber wrench!
Old Jul 1, 2013 | 02:44 PM
NmexMAX's Avatar
dot dot dot ...
That being said, the last time I changed my KS on my 4th gen, I didn't take the IM off.
IIRC, the OP's is an 01, and compared to the 05-99 and 02-08, I'd say it be easier to take the IM off. The VIAS hardware and vac lines get in the way.
Old Jul 3, 2013 | 10:18 PM
Thanks everyone,
Yeah I'm gettiny crappy Mpg....I see the vac lines and yes there in the way...lets just say this...myself or Shrek couldnt switch the sensor..lol
Thanks!
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
