NWP 75 mm throttle body installed, first thoughts
Old Aug 2, 2013 | 09:12 AM
  #81
Chris Gregg's Avatar
Get Off My Lawn
Depends on the tire specifications. Read your tire's sidewall. It will say something about Do Not Inflate Over xx pounds. It may also say to follow the car's factory recommendation for tire pressure.
Old Aug 2, 2013 | 09:45 AM
  #82
Prophecy99's Avatar
Originally Posted by CauzinDrama
Is 40 PSI safe?
yes it is safe in most cases, always check side walls though.
been riding around 42 psi couple years now
Old Aug 2, 2013 | 09:48 AM
  #83
CauzinDrama's Avatar
do you get excessive wear in the center of the tires
Old Aug 2, 2013 | 02:17 PM
  #84
knight_yyz's Avatar
Toolie
Old Aug 2, 2013 | 04:07 PM
  #85
melvinman2003's Avatar
Agreed. Always check side walls max psi. Mines like 68 psi so I got wiggle room. I have been running 40 psi on my cars for years with no issues. But it depends on the tire. My tires wear perfect on this. If I hit low 30's I get the sides wearing more then middle.
Old Aug 2, 2013 | 04:12 PM
  #86
TexasTex's Avatar
I have ran a few cars tires at around 40psi. It always feel a little rougher, but it does improve mileage and it feels more responsive as well. It could just be in my head, but that's my take.
Old Aug 4, 2013 | 12:53 AM
  #87
slimbim's Avatar
Where can I get a speed boster referred to ealier in this thread?
This 75mm TB kit is for '02 and higher Maximas, but I have an '00. Is there anysuch product for '00?
Old Aug 4, 2013 | 09:02 AM
  #88
maximasupermod's Avatar
Its called sprint booster
Sent from my IB Auto Group Forum App
Old Aug 4, 2013 | 11:29 AM
  #89
knight_yyz's Avatar
Toolie
You don't need a sprint booster on an 00 maxima. It's cable driven. I believe you may want the pathfinder TB
Old Aug 4, 2013 | 12:26 PM
  #90
schmellyfart's Avatar
Yup.
Old Aug 6, 2013 | 09:12 PM
  #91
Get Off My Lawn
No, the device works. But, it does not add horsepower or improve performance. It removes the (slight) electronic delay between pedal and throttle and increases the "gain." Meaning at stock, 1% pedal equals 1% throttle. Sprint booster adjust this ratio to 1% pedal - 10% throttle (don't recall exact ratio). So, more throttle with less pedal and you reach maximum throttle with less pedal.
Old Aug 6, 2013 | 11:45 PM
  #92
cdoublejj's Avatar
Originally Posted by JonBlz
in order to get rid of the throttle delay you have to get yourself a sprint booster.......bigger TB will make it respond better but the delay will still be there....sprint booster takes care of that issue, i know because i have one in my 02 max
I google that and it's a remapper, so you saying it's fuel map or computer limitation? i notice my stock car when i hit the pedal doesn't do any thing, it sits there for second then accelerates.
Old Aug 7, 2013 | 07:14 AM
  #93
NmexMAX's Avatar
dot dot dot ...
This is about NWP's 75mm TB, not about the Sprint Booster.
Go here for that:
http://forums.maxima.org/5th-generat...sprint+booster
Old Aug 7, 2013 | 08:22 AM
  #94
dwapenyi's Avatar
thousand
What you gain in gas mileage with your tires at 40 psi you lose in braking ability, cornering performance, and wear. Factory air pressure provides the best balance for everything.
Old Aug 8, 2013 | 09:50 AM
  #95
Gemner's Avatar
Originally Posted by dwapenyi
thousand
should note that is based on using the OEM tire size/spec and doesnt apply to tires on bigger wheels or tires of significantly different construction
Old Aug 9, 2013 | 06:52 AM
  #96
ranmas2004's Avatar
32 psi for ALL my cars, 86 Accord, 88 Accord, 92 Saturn SC2(trash azz car), 97 Maxima, 03 MDX, 02 Maxima, 99 Corolla and ALL tires for years no wear issues.
Old Aug 9, 2013 | 06:58 AM
  #97
OK this is a tire thread now!
Old Aug 9, 2013 | 07:58 AM
  #98
ranmas2004's Avatar
OK OK let me get back on track here....
I have the 75mm TB but not the NWP kit. I got it installed a couple years ago when I did my all motor build and I noticed that the response on the throttle was improved. Back in the day they did not have these nice PnP harnesses that connect the stock 02/03 TB harness to the 09 TB harness....so I had to use the FSM and make my own wiring connections and purchase AN ENTIRE 2009 engine harness just to get the pigtail for the TB off of it!
Old Aug 9, 2013 | 05:32 PM
  #99
knight_yyz's Avatar
Toolie
Installed my salvage yard 09 TB and my custom adapter plate. The elbow was opened up to 74mm, so my adapter plate is tapered from 76mm to 74mm across 1/2 aluminum plate. I will be taking it for a drive to work tonight. I already have noticed that when the car starts there is definitely a difference. I also ceramic coated the upper IM and elbow.
For the record. I have plans to put a 80mm BBMAF in the car this week. My car was runes with g35 injectors over a year ago but they were almost maxed out. So I have 440cc right now but not tuned. My afr is not right. Looking at about 11 at wot. Berk style intake.
Took the car to work tonight and even with the bad afr all i can say is holy crap! The car is pulling like a ****!
Old Aug 9, 2013 | 07:43 PM
  #100
Sorry off topic but what kind of radiator and hoses are you using. I think my radiator is in need of replacement soon.
Old Aug 9, 2013 | 08:06 PM
  #101
knight_yyz's Avatar
Toolie
4th gen Mishimoto rad with Obx upper hose
"OMG are you speeding or something?"
Quote from my wife after we went for a drive today. LOL
Old Aug 10, 2013 | 10:25 PM
  #102
Sweet! Thanks! Ya I definitely need one of those.
Old Aug 17, 2013 | 02:21 PM
  #103
Also 1 thing that makes the install much easier was the bottle cozy.... I thought that would be a great help to the people who haven't done this mod yet
Old Aug 19, 2013 | 12:32 PM
  #104
SicX6spd's Avatar
hey knight_yyz, would you happen to be able to throw up a sound bite on your setup??
Also, general question: on a 5.5 gen could I throw the 4th gen mishimoto radiator with 4th gen obx upper/lower rad hoses and a 350z thermostat and everything would be direct fit minus mounting the rad? My max is reaching 140k and needs cooling system upgrade I feel
Old Aug 19, 2013 | 05:23 PM
  #105
knight_yyz's Avatar
Toolie
This is my last dyno before the bbtb. I will make a new one when I dyno next Tuesday with the 80mm tb and 80mm MAF
Old Aug 20, 2013 | 09:23 PM
  #106
SicX6spd's Avatar
Sounds good knight, nice setup you have there! Wait did you say 80mm tb and maf? Can't wait for the sound bite of your new setup!
Old Aug 20, 2013 | 09:46 PM
  #107
Donkeypunch's Avatar
How much did it make?
Old Aug 21, 2013 | 05:05 AM
  #108
video link: Https://www.youtube.com/watch?v=us7fo-ahn64&feature=youtube_gdata_player
this is my last dyno before the bbtb. I will make a new one when i dyno next tuesday with the 80mm tb and 80mm maf
80mm..... xtreme!!!!! Things gonna turn some high numbers.
Old Aug 21, 2013 | 08:09 AM
  #109
knight_yyz's Avatar
Toolie
That dyno turned out 253.50 fwhp and 249.75 lb/ft tq Since then I have added the block plate and the 80mm TB. The 80 mm BBMAF is not installed but it is built. I have to ceramic coat it this weekend.
My dyno appointment is on Aug 27th
Imagine this with a velocity stack and a 6" inlet air filter
Old Aug 21, 2013 | 08:12 AM
  #110
NmexMAX's Avatar
dot dot dot ...
It's not uncommon. I've got a 100mm MAF/intake, as do quite a few others. I guess I should be getting a new TB soon then.
Old Aug 21, 2013 | 08:31 AM
  #111
95VQ30's Avatar
Back on subject.
I've had the NWP throttle body kit for about a month.
Throttle response is improved and I feel a slight bump in power, but the most noticeable changes are the throttle response and a slight decrease in MPG(but that could be from being rev-happy the past few weeks). I did have a SES light after the install but I did the relearn procedures(it took 3 times) and the light has not returned after about 1-1.5k miles.
Over all I am very happy with the kit and the installation shouldn't take more than 45-60 minutes for a novice. I'd gladly recommend it to any Max owner.
Old Aug 21, 2013 | 08:41 AM
  #112
NmexMAX's Avatar
dot dot dot ...
Originally Posted by 95VQ30
Back on subject.
What was the MIL for?
Old Aug 21, 2013 | 08:43 AM
  #113
95VQ30's Avatar
I'm sorry, MIL?
Old Aug 21, 2013 | 09:00 AM
  #114
MIL = SES.
I had one too.... It would be on at idle then turn off when throttle was applied. Nothing came up when scanned though... Couldn't clear it either with any of the apps I have, doing the ecu reset and throttle relearn fixed it.
Old Aug 21, 2013 | 09:03 AM
  #115
knight_yyz's Avatar
Toolie
You have to do the throttle relearn, there is more air getting through when the tb is at idle. I had no problems after the install.
Old Aug 21, 2013 | 09:33 AM
  #116
95VQ30's Avatar
p40..i forget- I'll check it on my lunch break, I have the notes at my apartment
Old Aug 21, 2013 | 09:55 AM
  #117
95VQ30's Avatar
Correction it was
p0507
Old Aug 21, 2013 | 10:10 AM
  #118
Yup high idle code!
Old Aug 21, 2013 | 10:45 AM
  #119
Fakie J Farkerton's Avatar
Whoever is mod on this thread..please PM me..
Old Aug 21, 2013 | 10:49 AM
  #120
NmexMAX's Avatar
dot dot dot ...
Your statements and pics are irrelevant to the topic at hand, and are in no way even related to Maximas nor this thread.
Stay on Topic.
