Strong gas smell at startup
Old Aug 2, 2013 | 04:31 PM
bennuss's Avatar
Very often I start the car I get a strong gas smell in the car to the point that I have to open the windows. I have no codes and the car runs fine without any smell past the start. I do have crappy mileage but I am attributing that to flaky upstream o2 sensors since i one had a code. It has since gone away.
Any ideas?
Old Aug 3, 2013 | 12:04 PM
DennisMik's Avatar
Remove the rear seat bottom cushion and you will see a round plate in the center. This is the cover to the gas tank fuel pump and sending unit. Take that plate off and see what you can see. Start the car while that plate is off and see what, if anythig, happens.
Old Aug 3, 2013 | 03:25 PM
RR5's Avatar
RR5
Yeah, pull the rear seat cushion and look at the large O ring. Just pick one up at the stealership and replace it. You could also inspect the fuel line coming off the fuel pump assembly.
Old Aug 3, 2013 | 08:06 PM
TravisCadello's Avatar
Because Racecar.
Old Aug 3, 2013 | 10:13 PM
bennuss's Avatar
Why do i only smell at startup?
Old Aug 3, 2013 | 11:55 PM
DennisMik's Avatar
That's a good question. Why don't you do some diagnosing and see if you can get some additional information for us?
Old Aug 4, 2013 | 05:23 AM
bennuss's Avatar
Which is precisely why I posted to this board; for ideas where to begin.
Old Aug 4, 2013 | 07:33 PM
DennisMik's Avatar
You were given some suggestions. Follow up on them and then ask more questions if the problem was not uncovered.
Old Aug 4, 2013 | 07:45 PM
RR5's Avatar
RR5
Here is a suggestion, check the FSM and reply back once you look at your fuel sender assembly.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
