Maxima Reverse with brakes noise
Old Aug 17, 2013 | 10:58 AM
Garrettz459's Avatar
Strange thing it been happening for at least a week but it not causing any problems though just some strange noise when I put my car reverse and applying the brakes it makes such as strange noise. Especially this happens when I'm downhill or uphill if the ground is flat it wouldn't make those noises.
This does not happen when I'm driving... it only happens when backing up.
Old Aug 17, 2013 | 11:23 AM
DennisMik's Avatar
Check that the splash shield is not bent into the brake rotor. Otherwise it could be the brake pads vibrating or chattering or squealing. If you think it might be the brake pads making the noise, you could try sanding them to break the glaze.
Old Aug 18, 2013 | 10:07 PM
I think I found the problem... I think it because the brakes pads aren't quite loosen up from the emergency brakes. Like I said it doesn't happen during forward only reverse. I'm gonna try check it out tomorrow morning see whats up.
Old Aug 20, 2013 | 12:10 AM
max ride 41's Avatar
i have this problem and i just did front and rear pads and rear rotors as well. only in reverse and only when the brakes are cold, sometimes on a hill as well.
Hondarydr
Dec 30, 2024 06:15 PM
spidgeon
Aug 18, 2015 05:46 AM
egali045
Aug 16, 2015 01:19 PM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
