Coolant brand
Old Jan 15, 2002 | 09:15 PM
woosh's Avatar
Coolant brand
Just curious,
Do you guys purchase the nissan coolant or another brand (please state)? do you follow the 50% coolant 50% distilled water mix?
Old Jan 16, 2002 | 12:01 AM
CalsonicSE's Avatar
I use about 85% H2O, 15% percent coolant, and one bottle Redline Waterwetter. Technically, it cools better than a 50/50 H2O & coolant mixture. I don't have to worry about the water freezing cuz I live in CA & Waterwetter supposedly has anti-rust/anti-corrosion ingredients.
Old Jan 16, 2002 | 12:08 AM
NoHalo's Avatar
The waterwetter looks good. Thanks...
http://www.redlineoil.com/redlineoil/wwti.htm
Old Jan 16, 2002 | 04:47 AM
2k2kev's Avatar
It's chrome alright...
anyone from 'up north' - ???
Would this freeze in winter? That might not freeze in CA but what about further north, like Maine or Canada?
Old Jan 16, 2002 | 02:07 PM
theMax's Avatar
50/50
I'm in ohio and stick with the 50/50 mix.
I use havoline's 5-year/150,000 mile coolant (orange not green).
Old Jan 16, 2002 | 04:28 PM
CalsonicSE's Avatar
Re: anyone from 'up north' - ???
I'd stick with the 50/50 mixture in areas with cold climates. Don't wanna risk anything. Nevertheless, a bottle of Waterwetter wouldn't hurt.
Old Jan 16, 2002 | 07:03 PM
2001AESE's Avatar
I'm not sure how the 85/15 ratio of coolant and water cools better. Most manufacturers recommend a 50/50 mixture here in Canada and this also prevents the coolant from getting too thick and not flowing well in the newer engines when it gets cold. Upto about 70/30 coolant/water is about as far as I would go and this tends to have a lower freezing point (depressed freezing point in chemistry), but a slight worse (lower) boiling point. Having a low ratio of coolant may not provide enough of the corrosion inhibitors that the coolant should provide in new aluminum component engines; using distilled and deminineralized water also helps prevent scale build up in our higher compression/hotter engines.
Old Jan 17, 2002 | 12:09 AM
CalsonicSE's Avatar
H20 is a far better cooling medium than coolant. Actually, a lot of people who go road racing use all H20.
Manufacturers recommend the 50/50 mixture because cars are sold in all areas with all different kinds of climate; the 50/50 mixture will work in the Sierra Mts as well as in the desert with no problems.
Like I said, I don't have to worry about freezing point because I live in SF where it never freezes nor will I drive to the mountains. And like I said, Redline Waterwetter has rust & corrosion inhibitors. Some may be wary, but I for one trust Redline products.
Old Jan 17, 2002 | 06:42 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I believe I have 75% watter and 25% coolant with a bottle of Redline Waterwetter. Turbo95Max tried convincing me to use all water but I didn't want to.
Old Jan 17, 2002 | 02:04 PM
theMax's Avatar
coolant
I'm not saying this will happen with water but can't you cool your engine to much?
I know race cars cover portions of the radiator with tape to increase the water temp if it is running to cool.
Something about an optimal temp.....
Miket2006
Mar 1, 2021 03:55 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
