Need some advice... on cattman headers
Old Sep 8, 2013 | 05:54 PM
Klikzzz's Avatar
I've already searched the forum... but I thought this might be a quick way of getting some useful advices.
I've got a cattman headers tht id like to install on my 2003 maxima.. but wondering if it will help me.
The current situation of my 2003 maxima is that its got a CEL light throwing a code for Bank 1 sensor. And my pinging at 2000 rpm have gone worse, so im thinking it could be that my precats are gone as well...
So can i just intall the headers and hope the pinging goes away? I'm assuming I'll need the O2 sims for the CEL light.
Please chime in!
Old Sep 8, 2013 | 07:35 PM
TriniSpeC's Avatar
So if you think the problem lies in your precats, then by replacing them the problem should theoretically be solved.
Old Sep 8, 2013 | 07:41 PM
knight_yyz's Avatar
Toolie
colder plugs would be easier
Old Sep 8, 2013 | 07:42 PM
Klikzzz's Avatar
Knight_yyz....i did switch to colder plugs...no change
Old Sep 8, 2013 | 09:11 PM
Chris Gregg's Avatar
Get Off My Lawn
Both front sensors are used to regulate fuel mixture. If the sensor is bad, eliminating the cats won't help. Although, I understood the system is designed to switch to the rear sensor if the first stops working properly. So, that's not to say there isn't an issue with the cats.
In any case, if you plan to keep the car, do the install but anticipate maybe having to change that one sensor. I also highly recommend going to a 4th gen (IIRC) lower oil pan. It moves the oil drain from facing the rear to facing the passenger wheel. Makes changing the oil due to the proximity of the y-pipe, MUCH easier and avoids getting oil on the exhaust each time. I believe the panics only about $50 through www.nissanpartsasap.com (though I suggest you just call if you have trouble finding the part).
Old Sep 8, 2013 | 09:46 PM
knight_yyz's Avatar
Toolie
Damn, I didnt know this could be done. I hate oil changes after the header install
Old Sep 8, 2013 | 09:51 PM
knight_yyz's Avatar
Toolie
As for the sim, I highly recommend you just extend the secondary o2's to behind the main cat. The sims are hard to come by and they don;t seem to last very long.
Nick knows how to extend the o2's properly if you are out in the east end of TO.
Pinging may also be due to a small air leak though. The ****ty gaskets all around the plenum tend to be garbage. The black "coating" can become brittle and start to flake and cause leaks. I've seen this on a few spacer installs.
Old Sep 9, 2013 | 12:37 PM
Klikzzz's Avatar
great suggestions.... but im seeing if I can sell the car...but appreciate it!
Old Sep 9, 2013 | 04:10 PM
Get Off My Lawn
Ooohhh, suppose there's going to be a new for sale thread for header/Y. Somebody better ******'em up!
Old Sep 10, 2013 | 06:58 AM
NmexMAX's Avatar
dot dot dot ...
I wonder if the Gen I Cattman headers are slightly different design since I have yet to (never say never!) get oil on the exhaust during an oil change, and never has been an issue for me to even think about.
Old Sep 10, 2013 | 07:32 AM
knight_yyz's Avatar
Toolie
Food for thought on the pinging.
Last week I went for a dyno tune with the BBMAF and I lost a ton of low end torque. So for ****s and giggles I put the VIAS butterfly back in the car. At low rpm and cruising my AFR is still at exactly 14.7, at WOT it is a little more rich than it was. BUT!, at cruising and light acceleration I am pinging like a **** with one step colder plugs. I'm removing the VIAS later today.
The problem with the new gen headers is the skid plate for the most part.
Old Sep 10, 2013 | 07:53 AM
TallTom's Avatar
Interesting. And you had no pinging with the VIAS delete?
Old Sep 10, 2013 | 09:09 AM
knight_yyz's Avatar
Toolie
Never with the colder plugs. Right now with the colder plugs it's all I can hear. it isn;t even hot out the last few days.
Sorry, I just noticed something. Putting the VIAS back in, leaned out heavy acceleration and WOT by a wee bit according to my wideband, but normal driving did not change
Old Sep 10, 2013 | 09:11 AM
TallTom's Avatar
That's nuts. Is the pinging in the initial part of giving it throttle when driving or all through acceleration?
Old Sep 10, 2013 | 09:23 AM
knight_yyz's Avatar
Toolie
light throttle, cruising, going up a hill. I have other problems right now with the car that I am aware of, but the car was not pinging when I left the dyno. And it was a hell of a lot hotter on dyno day than the last few days since I put the VIAS back in.
I'm in the middle of doing something else to the car right now but i will take it for a drive. The VIAS is gone but I am experimenting with durometer ratings on my custom engine mounts.
Old Sep 10, 2013 | 09:32 AM
TallTom's Avatar
Cool. I am curious to see if the ping disappears now that you took the VIAS back out. I wonder how the VIAS leaned out the mixture.
Old Sep 10, 2013 | 09:46 AM
Get Off My Lawn
I thoight first gen Y's were unequal length, so the "loop" that hugs the oil drain plug in the new versions don't exist. Though, I thought I read where you had second gen headers/Y!?
Old Sep 10, 2013 | 09:51 AM
NmexMAX's Avatar
dot dot dot ...
I've got first gen units. The original 3 piece design.
Old Sep 10, 2013 | 10:35 AM
knight_yyz's Avatar
Toolie
your loop is more round, the newer ones are oblong. I was just under the car i should have taken a photo
Old Sep 10, 2013 | 01:29 PM
knight_yyz's Avatar
Toolie
Ok, so took out the VIAs, I have to idle air relearn, but it is hot as hell out today. But my pinging is gone after taking it for a spin.
Old Sep 10, 2013 | 01:44 PM
TallTom's Avatar
Wow!
Old Sep 10, 2013 | 07:06 PM
george__'s Avatar
I have a weird ticking noise too but only when I floor the car or go up hills. I was told it was due to the injectors and to live with it, not true?
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
Chaka
Sep 17, 2015 09:53 AM
Samedi
Sep 3, 2015 01:07 PM
