2003 power window problem
Old Sep 29, 2013 | 03:58 PM
Castorriver's Avatar
I just bought my Dad's old Maxima when he got a 2013. Problem is: when I roll up the driver's window all the way, it comes right back down about 4 inches. I have to stop about 6 inches from the top and bump it up about an inch at a time to get it all the way up, or roll it up then turn the key off so it stays. He said it's been doing this for a while. Otherwise, the window operates as it should. Any ideas?
Old Sep 29, 2013 | 04:36 PM
knight_yyz's Avatar
Toolie
Search will yield you the answer. Remove the panel and hit the reset button
Old Sep 29, 2013 | 06:29 PM
IceBerg's Avatar
Easy fix
Old Sep 29, 2013 | 07:57 PM
02nismaxlegnd94's Avatar
easy fix, my passenger side does the same thing, I'm just lazy to remove the driver door panel. i inquired at the dealership about it when i was getting my airbag igniter replaced, they told me that my motor is on it's way out. i laughed and told them i can fix it myself.
Old Oct 5, 2013 | 04:54 AM
IceBerg's Avatar
Door panels doesn't need to be removed I just removed the switch
Old Oct 5, 2013 | 04:04 PM
mikeBal's Avatar
simpler
If you remove the little garbage collector/handel you should be able to see and reach the relearn button from there.
Button should be straight down behind the plastic (you can press it through the plastic)
1) put car in acc with the window up.
2) Hold button & roll down window (DO NOT USE AUTO)
3) ??? Do not release button???
3) roll window back (DO NOT USE AUTO)
4) Turn off ignition
5) If it didn't work restart skipping step 3
Old Oct 5, 2013 | 05:27 PM
tosheto's Avatar
I used this procedure on both front windows and worked great first time. I only removed the window switches.
Old Oct 6, 2013 | 03:35 PM
thanks for the shortcut fellas, much appreciated.
lowpost99
Oct 26, 2025 06:53 PM
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
