HELP!!! No Pressure in Clutch
Old Oct 5, 2013 | 06:28 PM
latinusmaximus's Avatar
I just replaced the slave and the lower clutch hose on my 01 Max. Now I cant get any pressure in my clutch. I sat there and pumped the clutch for about an hour and still no pressure. Before all this, it would occasionally get to the point where I had to pump the clutch because the reservoir was empty and there was no pressure in the line due to a hole in the lower hose, so after about 45mins-1hr I would get pressure. I even went as far as repeatedly pressing the piston on the slave to see if it would get an pressure and it seemed like it did but still no pressure in the clutch. Anyone got any ideas?
Old Oct 5, 2013 | 07:58 PM
venturous's Avatar
Did you bleed the clutch?
Old Oct 18, 2013 | 04:45 PM
Yeah I finally got pressure in the clutch after reverse bleeding it but it still feels soft and there are times I have to force it into gear.
Old Oct 18, 2013 | 05:19 PM
SSJRICH's Avatar
Probably have a problem in the master or you still have air in the system.
Old Oct 18, 2013 | 06:12 PM
maxima.713's Avatar
You got an aftermarket clutch?
You may want to replace your master.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Mar 12, 2020 12:06 AM
carlosvq30
Sep 26, 2015 09:44 AM
