Ac broke in the car, what's the damage?
Old Oct 6, 2013 | 11:10 AM
Scott LaRock's Avatar
Just hit 200k on the clock of my 2002 max. Started the car hit the ac and bam!!! Nothing, seems like the compressor failed but no blowing or anything.
Can I get a second hand compressor
Press or for cheap?
Old Oct 6, 2013 | 12:43 PM
Donkeypunch's Avatar
If the 2002 max is like a 2000 it's pretty cheap to replace.
Universal Air Conditioning CO10552C New A/C Compressor with Clutch : Amazon.com : Automotive Universal Air Conditioning CO10552C New A/C Compressor with Clutch : Amazon.com : Automotive
Old Oct 6, 2013 | 02:40 PM
DennisMik's Avatar
if the refrigerant leaks out, there is a pressure sensor that won't allow the compressor to run. Have a shop check and see if all it is is low R134A refrigerant.
Which brings up the question, does the compressor run?
Old Oct 6, 2013 | 02:44 PM
Child_uv_KoRn's Avatar
Bad *** Newb
LOL. If the compressor failed, then you'd know it b/c the belt would be squealing and it'd burn up. There's a leak somewhere.
Old Oct 7, 2013 | 01:04 AM
RR5's Avatar
RR5
+1 on the leaks, check this video
Find the leak, replace the part and re-check.
Old Oct 7, 2013 | 07:34 AM
Galactica's Avatar
The compressor on my 01 failed and what happened was a big bang and I discovered that the clutch locked to run the compressor and the internals had gone bad so the clutch blew right off the compressor shaft and the belt just kept turning the wheel of the compressor, but that shaft going into the compressor was seized up. I didn't buy a reman, but I put in a new Calsonic compressor. Still had what refrigerant was in there, plus refilled the system and all was well. Cost about 350 to replace.
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Samedi
Aug 12, 2015 01:54 AM
Team STILLEN
Aug 10, 2015 04:29 PM
