Shift Bezel Repaint???
Old Oct 12, 2013 | 07:55 PM
David3267's Avatar
Ok I had a 2k2 shift console and I swapped my trans with a 4th gen and the shifter rod is shorter then as the 5th gen tranny so I cannot drive with my 2K2 console anymore so I went back to stock and does anybody have any suggestions on how I can sand this and paint it to look fresh like the rest of the trim in my car? Paint numbers? Sanding? Anything to help thanks guys
After trans swap....
Went back to the stock ugly 5th gen boot
Just needs to be sanded and painted
Old Oct 13, 2013 | 01:19 AM
RR5's Avatar
RR5
You could find that at a local salvage yard or look on car-part.com
Old Oct 13, 2013 | 01:46 AM
ShocknAwe's Avatar
I know of a guy over in the UK who does shift bots for our cars if that helps
Old Oct 13, 2013 | 04:18 AM
colt149's Avatar
Painting
Try to sand it with 3m 400 grit sand paper, until the surface is smooth , apply 3 coats of epoxy primer let it dry for 24 hours, smooth the primer surface with 400 grit sand paper with water.
With area , unable to smooth out, you can apply a thin coat of Bondo filler, dry it for 1 hour, coat the area with expoxy primer, dry it for 3hours , sand the area with 400 grit. Let it dry, apply a thin coat of vinyl paint let it dry for 1 hour, sand it with 1000 grit with water, let dry for 30 mins, then apply second coat, let it dry for 1 hour. Apply the last coat.
Old Oct 14, 2013 | 08:38 AM
David3267's Avatar
Yoooo thank you im gonna give this a try this weekend ill post results
Old Oct 14, 2013 | 08:39 AM
David3267's Avatar
Really? What does he charge?
Old Oct 14, 2013 | 10:41 PM
Mules5555's Avatar
I sanded mine down and painted it. A year and 27 thousand miles later it still looks great.
Old Oct 15, 2013 | 06:59 AM
David3267's Avatar
Can u upload a pic or email me one on ur results????? What color code did u use??? I want it to like like factory
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
