ICU imobilized if detached?
Old Oct 20, 2013 | 09:28 AM
blackmax42's Avatar
I've found a few conflicting references to this so if anyone knows for sure..
2001AE manual transmission with likely ECU/ IACV issues....
Q: If I remove ECU and detach it - does ECU then become immobilized from starting- the car.... if I just I open it then put it back in again?
I would then need a dealer reflash to pair it with the key.
I want to open it and see if it's fried...
Thanks!
Old Oct 20, 2013 | 09:57 AM
Gemner's Avatar
no if you just pull your ecu, work on it without changing any NATS/IMMO stuff on it, and replace it there is no issue.
Old Oct 29, 2013 | 10:02 AM
blackmax42's Avatar
Confirmed. Car still starts after disconnecting and reconnecting the same ECU.
Pulled the ECU (can they possibly give you less room to put a (8mm) wrench in?@!??). Yes component was fried. My route: Junkyard IACV and STA509A from ebay. And I'll solder it myself...
Old Oct 29, 2013 | 10:41 AM
DennisMik's Avatar
Oh yes they could and did. Try removing the ECU on a 4th gen.
mdeal
Jul 19, 2017 09:49 AM
conansriver
Sep 3, 2015 06:38 AM
nismos14
Feb 26, 2004 05:41 PM
hyuin001
Jul 15, 2003 02:01 PM
