Climate control lights
Old Nov 7, 2013 | 06:26 AM
rkspec's Avatar
Hi All,
First post, so please dont be a repost haha
I did a quick search, it showed how to remove the unit but not how to replaced bulbs.
The ones in red are out/blown, can i replace the bulbs with out removing the entire stereo/HVAC unit from the dash? How are the bulbs replaced meaning can you pry off the face of the HVAC?
Old Nov 7, 2013 | 06:33 AM
rkspec's Avatar
Also...should the steering wheel radio/cruise buttons light up at night?
If so, i assume i just pry the controls off to get to the bulbs?
2001 Maxima AE
Old Nov 7, 2013 | 06:44 AM
TallTom's Avatar
You pull the hvac unit out of the dash and then remove the rear cover of the hvac unit. The bulbs twist out from behind. you do not need to remove the face of the hvac unit.
http://home.comcast.net/~kcmurphy72/i30/HVAC.pdf
Old Nov 7, 2013 | 06:53 AM
rkspec's Avatar
Aaahhh...ok easy enough.
Thanks Tom!
Old Nov 7, 2013 | 09:22 AM
Amerikaner83's Avatar
^^ correct.
And the cruise control stuff on the steering wheel is NOT supposed to light up.
Old Nov 7, 2013 | 04:28 PM
rkspec's Avatar
great appreciate it
/thread
Old Nov 7, 2013 | 06:25 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
Damn Tom you put it down with that link. All I can add is IBTL!
Old Nov 7, 2013 | 08:17 PM
TallTom's Avatar
I found it in an old thread and actually used it to replace mine.
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
