need help with this wiring ASAP please!
Old Nov 10, 2013 | 12:39 PM
TTwizted13's Avatar
im in the middle of adding the directed keyless entry system as my car didnt come with one.
got everything but lock/unlock. it says in the DDM.
i pulled the door apart, found and tested the wires... now how the efff do you run wires through?!?!?!? isnt there a tap at the ECU somewhere?
i saw pictures the other day someone took of all the install wire locations on a 5th gen but now searching i cant find anything.
if you can find those pictures that would be awesome! or tell me how to run these darn wires through to the door!
thanks in advance!
Old Nov 10, 2013 | 01:10 PM
Reizy's Avatar
I used this. http://maxima.theowensfamily.com/viper791xv/ Step 27b for you. Make sure you get the pulses set right from the alarm. I think unlock takes 2 pulses?
edit: Or wait for someone to tell you if you can tap the SECU under the dash. It may be an option.
Old Nov 10, 2013 | 01:52 PM
TTwizted13's Avatar
thanks!
i got the lock working properly, unlock needs programmed for double pulse.
now for some reason trunk release isnt working, and neither is the horn honk... ughh this is such a headache!!!!
Old Nov 10, 2013 | 02:44 PM
TTwizted13's Avatar
got it all working now.
was trying to beat the sun going down and i won lol
for some reason the horn only honks if you double press it. its weird, but ill call directed for that tomorrow. as of now, everything works!
thanks
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
