New motor or rebuild my current one?
Old Nov 15, 2013 | 03:34 PM
Stuart Ramsey's Avatar
So my motor is showing signs of needing some hard work and I'm trying to decide whether or not to find a new one or rebuild this one? What do y'all think? I'm looking to spend as little as possible without cutting corners. Help me out guys, I'm open to all advice.
Old Nov 15, 2013 | 03:41 PM
NmexMAX's Avatar
dot dot dot ...
So what's the problem with your engine? Specific?
Old Nov 15, 2013 | 04:34 PM
Well first things first it has 215978 miles on it. I can barely go 3,000 miles before I start getting some quick flashes from my oil light when I crank the car. Also when it gets close to having to change the oil I can hear lots of noise coming from the timing chain. The magic spot to get this noise is around 1500 Rpms at 42-50 mph. Also in the morning at the first start is noisy until it warms up. And at other times throughout the day it just feels sluggish, and I have to really get on the gas to get it going. Hope this helps.
Old Nov 15, 2013 | 04:38 PM
Shift_A32B's Avatar
The way I see it is:
1) If you buy a used engine, you don't know how much it will last. You don't know what abuse the engine has gone through.
2) If your current engine gets rebuild by a trustworthy mechanic or yourself, you can feel better that the engine can last up to 300k ....hopefully.
Old Nov 15, 2013 | 04:42 PM
So maybe a rebuild is the best way to go unless I can find a really badass motor somewhere but I don't even know where to start when it comes to shopping for a new motor.
Old Nov 15, 2013 | 05:41 PM
DjHackStyle's Avatar
www.car-part.com
Id go with a used motor low mileage
Old Nov 15, 2013 | 05:53 PM
Fatboy98maxima's Avatar
Dude if u get quick flashes from oil light u doing something wrong like not looking at oil levels every few days knowing that our cars have a tendency to leck oil
Old Nov 16, 2013 | 12:14 PM
ACee's Avatar
Stroke it
Old Nov 16, 2013 | 12:33 PM
Sorry ha but can you elaborate on what you mean by stroke it?
Old Nov 16, 2013 | 12:35 PM
IceBerg's Avatar
A friend of mine had same symptoms timing chain rattle,loud until warm,oil light flash etc thought he needed a motor until we changed the oil and there was barely none he was loosing a lot of all through leaks oil pan ,valve cover never one drip though.changed oil and added Lucas oil stabilizer ,all symptoms are gone been a month now.i would have a mechanic have a very good look before doing a rebuild
Old Nov 16, 2013 | 12:38 PM
Thanks man I'll get on that asap
Old Nov 16, 2013 | 08:14 PM
venturous's Avatar
Are you periodically checking your oil level, or at least checking it when you get these symptoms?
Old Nov 16, 2013 | 08:21 PM
VQnBEYOND's Avatar
Check this link out if you want power!
http://www.zfever.com/v1/Services-Engine-Builds-VQ35DE/
Old Nov 16, 2013 | 11:41 PM
tosheto's Avatar
If you are looking at low cost alternative, go with low mileage used engine. Check on prices for parts and labor if rebuilding the engine. It will add up very fast. How do I know? Because I have done it myself.
Old Nov 17, 2013 | 12:24 PM
ACee's Avatar
I was thinking that there is a stroker kit available, but it might not be the low cost alternative you are looking for.... You are best replacing the motor. Maybe you can find one out of a Quest or something?
Old Nov 17, 2013 | 01:57 PM
RR5's Avatar
RR5
I got 276,xxx on my VQ and have much the same symptoms. Buying a used engine might work out better since it's already out of the vehicle. This makes it easier to work on, tear down and so on.
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Vequity
Sep 10, 2015 05:26 AM
