P1320 again!!! After 3 month-- replaced Nissan OEM coils and NGK plugs
Old Nov 25, 2013 | 05:23 PM
wcasskicker's Avatar
I've had P1320 codes for over 2 years on my 2000 Maxima but car never stalled and drived fine for that time being. 3 month ago, I decide to fix the problem so I replace all 6 new nissan OEM coils 22448-2Y000 and 22448-2Y005 along with all new PFR5G-11 NGK platinum. The CEL code quick went away......for 3 month.....
Today the CEL code came back with only P1320 like before, Car still drives fine.
I could troubleshoot again by testing each coil to see which is triggering the CEL, but I want to know if there are any other sensors that would trigger
P1320??
Thanks,
Old Nov 26, 2013 | 06:09 PM
anyone?
Old Nov 26, 2013 | 06:26 PM
Child_uv_KoRn's Avatar
Bad *** Newb
P1320??
Thanks,
It sounds like one of the coils is out of spec, again. I would test each one. It's a stupid code that doesn't mean anything. But it will screw you if you live in a bastard area that requires emissions.
If not, then a harness wire may be damaged and you need to troubleshoot those. It was an issue on the 4th gens.
Old Nov 28, 2013 | 01:19 PM
Dj*Bogus*31's Avatar
Ugh......Im getting the same stupid code p1320. Failed Emissions cus of it. Im going to have to check the harness to see if this is the issue.
Old Nov 28, 2013 | 10:27 PM
To trouble shoot the harness, do I test the voltage on each one like how I test the coil? If one is found faulty, do you know if Nissan sell just one harness plug?
Also, would faulty crankshaft sensor also trigger P1320?
Thanks for the reply!
Ben2003GLE
31
Jul 17, 2016 08:13 AM
vingodine
45
May 21, 2016 12:46 PM
Turbobink
Aug 15, 2015 07:20 AM
kirkhilles
Aug 8, 2015 10:53 AM
maxima297
Aug 3, 2015 12:50 PM
