2002 Nissan Maxima Rear Camber
Hello All,
I have a 2002 Nissan Maxima SE 3.5 engine and i am having rear camber isssues.I have called multiple places online and in town and apparently the rear camber on my car cannot be adjusted.I have called performance shops and no one can tell me how i can get this issue resolved.I have inner tire ware and just bought new tires and need them to last me as long as possible. Also have had several alignments done and still no luck.Can anybody please advise how i can get this fixed.Any information would be greatly appreciated.
Is the inner tire wear on both rear tires? You cannot adjust camber since the rear is just a solid beam.
This means something is likely broken or bent or something. Have a mechanic check it out on a lift.
Edit: it is common knowledge to ignore George.
Inspection is a must. There have been a few guys through here who have reported bent rear beams. Although, I would had hoped if the numbers are off, the mechanic would have done an inspection. Good luck.
In the meantime, maybe run an already worn set on the rear until this gets resolved.
District
Aug 15, 2015 08:23 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
julian888
Aug 6, 2015 04:39 AM
