Quick valve cover gasket question.
Old Dec 6, 2013 | 12:08 PM
Donkeypunch's Avatar
Real quick my 2000 max is leaking oil, bad, out the covers.
Mostly the rear.
Is this all I need to fix it and replace all the gaskets?
Beck/Arnley 0376116 Auto Part : Amazon.com : Automotive Beck/Arnley 0376116 Auto Part : Amazon.com : Automotive
Beck Arnley 036-1579 Valve Cover Gasket Set : Amazon.com : Automotive Beck Arnley 036-1579 Valve Cover Gasket Set : Amazon.com : Automotive
Old Dec 6, 2013 | 07:39 PM
foodmanry's Avatar
Da Roller Coaster!
You need valve cover gaskets and spark plug gaskets. You also need RTV sealant for corners of valve covers. Use and follow FSM on replacement.
Old Dec 6, 2013 | 09:03 PM
litch's Avatar
common sense too mang. IIRC the spec is 90 on the bolts... When I did em I tightened to 60 on all the bolts, then to 80, then to 90, so that I didn't damage the gasket. This way you tighten down the cover evenly.
Old Dec 7, 2013 | 07:57 AM
I'm assuming that's 90 in/lb.
What is FMS? and is that all I need to take off the intake?
Old Dec 7, 2013 | 09:37 AM
Fakie J Farkerton's Avatar
Inch pounds, and a link to the FSM is in my sig.
Old Dec 7, 2013 | 11:06 AM
ok.
I just ordered that stuff and I'll find out if there's anything else needed
when it happens.
Old Jan 14, 2014 | 11:05 AM
Outatime28's Avatar
I'm doing the same job soon and I can't find the guide anywhere in the FSM. what category is it under?
Old Jan 14, 2014 | 11:11 AM
Don't even try to look on that thing.
Go to youtube there's a guy who does it step by step.
Old Jan 14, 2014 | 05:11 PM
DjHackStyle's Avatar
link by any chance? interested
Old Jan 14, 2014 | 05:28 PM
ACee's Avatar
Valve covers are pretty simple. I used 2004 vc's on my 03, add the copper gasket sealer, add extra in the two (or four total corners)corners near the timing chain cover, and torque (and loosen) bolts in sequence per fsm. Done. Not sure if it is exactly the same for 00,01,or 02 but cannot be THAT dam different.
Old Jan 15, 2014 | 08:08 AM
Outatime28's Avatar
I just did a quick search and didn't see anything. I have a basic understanding of the job and it does seem simple, but I'm not sure on how/where to apply the sealant and what the proper torque sequence is. A video or FSM help would be nice.
Old Jan 15, 2014 | 10:35 AM
ACee's Avatar
http://rs993.pbsrc.com/albums/af58/a...0?t=1389810659
Bolts
http://rs993.pbsrc.com/albums/af58/a...0?t=1389810663
Sealant.
Old Jan 15, 2014 | 04:07 PM
The hardest part is the brackets that hold the intake to the engine.
It's a real pain to get too. On my 2000 there are 3 bolts and had to use a low profile socket and ratchet.
Old Jan 16, 2014 | 07:20 AM
Max_Gator's Avatar
Yes. That is a major pain to even find those, let alone loosen them.
Also op, please consult the fsm. Read the specific procedure. Be educated about what you are doing.
Old Jan 19, 2014 | 11:07 AM
Outatime28's Avatar
You haven't answered our question of WHERE in te fsm the guide is...
Old Jan 19, 2014 | 11:42 AM
CMax03's Avatar
Make sure everthing is 100% clean on the mating surfaces, use your RTV at the Cam and cover joint mating surfaces, ensure the valve cover is debris free in the seal groove!
Old Jan 19, 2014 | 12:23 PM
ACee's Avatar
What do you exactly want to know?
Old Jan 19, 2014 | 02:14 PM
Outatime28's Avatar
Like where in the manual. I can't find it.
Old Jan 19, 2014 | 02:17 PM
ACee's Avatar
Where what? I thought I posted the correct pages. Its under rocker. Because its the rocker cover.
Old Jan 19, 2014 | 03:35 PM
Outatime28's Avatar
Pardon my ignorance... Lol
Old Jan 19, 2014 | 03:49 PM
i8acobra's Avatar
If you're doing the valve cover gaskets, do yourself a favor and do the plugs at the same time. No sense in removing the intake manifold twice.
Old Jan 19, 2014 | 03:56 PM
Phantasm's Avatar
replace the EGR too
Assuming it is the same as my 2002 you might as well replace the EGR valve while you have the cover off. mine was attached to the cover. ( 3.5L )
And yes, replace the spark plugs.. Check the coil packs when you pull them, if they are wet with oil on the stems, get the oil out of the well before you pull the plug or it will drain in to the cylinder ( ask me how I know ).
Old Jan 19, 2014 | 05:25 PM
ACee's Avatar
It's ok. I was getting confused with myself almost. Lol.
Old Jan 23, 2014 | 09:15 AM
MAXIMARK's Avatar
2003 to 2004 Valve Cover swap...
hey guys, I am going to change the valve covers and gaskets on my m-i-l’s 2003 Maxima. I have some experience having done this on my 1995 Max. With my ’95 I was able to get all the gaskets and the R&R went smoothly - remove, clean, install. I did a spark plug change on her car not long ago and noticed that the #5 spark plug tube had some oil in it. So now I am upgrading to the 2004 valve covers. I understand that the spark plug tube seals are already built in to the plastic VC. When I did my ’95 I had to use new rubber grommets and steel washers. Twenty of these jewels at around $3.00 each! Now with the plastic VC I read that I don’t use the grommets and washers. Do I just reuse the ’03 bolts on the plastic ’04 valve cover? I have the FSM data and the inch pound values to torque the bolts on the new VCs. Any other bits of wisdom others would share that have already done this job would be appreciated.
Be Safe, Mark V.
Old Jan 23, 2014 | 09:30 AM
tosheto's Avatar
I just reused my old bolts. I do not see a need to get new ones. The 03 should be easier to do than the 95. Good luck!
Old Feb 11, 2014 | 05:36 PM
Roymg's Avatar
2003 Gaskets
I have to admire you guys for doing your own gasket replacements. I just replaced mine but I let the dealer attack that job. I looked at what was involved and if it wasn't for the manifold being in the way I probably could have just snugged up some on the backside cover bolts. But I could not see them to do this. So I had Nissan do the job and also add new plugs (97,000 miles). $700 bucks.
Old Feb 12, 2014 | 05:06 AM
Max_Gator's Avatar
If you are saying use gasket sealer on the entire gasket, that is incorrect. The only place the fsm calls for rtv is in the corners.
I echo the suggestion about following the procedure in the fsm.
Wow. I prefer to do it myself and save $650.
Old Feb 12, 2014 | 05:15 AM
ACee's Avatar
^^^^this.
Old Feb 13, 2014 | 09:20 AM
MAXIMARK's Avatar
UIM removal and a CAUTION!!!
$160.00 in parts from the dealership that included the oil cooler gasket. $160 verses $700 - you do the math. The 3.5 UIM really is not that hard in comparison to my 1995 3.0.
Just follow the instructions at http://www.greghome.com/Greg%27s%20G...eplacement.htm Twenty-nine pictures with captions. The satisfaction of no leaking oil running down the exhaust shields and dripping onto the garage floor is great.
One major caution if you are going to take off the UIM for replacing the rear VC gasket or whatever... DO NOT MOVE THE THROTTLE BODY BLADE!!! It is almost irresistible when you see how dirty it is, but don't do it! Use TB spray and spray around it - do not push open the blade or you may get the P0507 DTC. Then you'll have to get a stopwatch and play the idle air volume learning procedure game. My idle went up around 900 RPM and was tripping the too high idle code. After doing the procedure multiple times it is once again below 700 RPM. Oh well I learned something new as always. I just wish I had read the warnings here before I pushed open the blade to clean the TB... Now cleaning the 3.0 TB is a piece of cake!
Be Safe, Mark V.
Old Feb 13, 2014 | 02:47 PM
Roymg's Avatar
I agree with you, but I'm beyond working on cars now like I use to do out of the necessity of having to raise a family and pay bills. I could not afford to pay someone to work on my cars especially things like brakes, water pumps, belts-hoses, ac, systems, hydraulics, etc. That's all changed now.
Old Feb 14, 2014 | 05:13 AM
Max_Gator's Avatar
Fair enough. It is actually a hobby for me.
Old Feb 14, 2014 | 10:33 AM
LabbRat's Avatar
OK, what catagory is "rocker" under? I looked in EM (Enginge Mechanical) and coudn't find it. Am I looking at this FSM right? I downloaded the entire zip folder for a 2003.
Old Feb 14, 2014 | 10:48 AM
ACee's Avatar
I searched the pdf file in EM for "rocker" and it first appears under timing chain cover section and then under timing chain. 1st page is EM-22
Old Feb 14, 2014 | 12:25 PM
LabbRat's Avatar
Cool, thanks I'll check it out!
Old Feb 14, 2014 | 01:53 PM
ACee's Avatar
yw
tgreen
Oct 18, 2015 06:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
