Can't Find an Oil Leak
Old Dec 8, 2013 | 09:32 PM
ramriv777's Avatar
Okay, today I was changing the oil and noticed the alternator and a/c compressor were drenched in it. I had the alternator replaced about a month ago, and it was brand new. I was expecting to find it in the same condition, but now it looks like it's 10 years old. Its appearance is not what I'm concerned about. I'm worried that the oil may damage it. I also replaced the vc gaskets about 6 months ago, and the oil cooler seal about 4 months ago. It seems to be around the top front area of the engine. Any idea where the leak could be? Thanks.
Sent from my iPad using MaximaOrg
Old Dec 8, 2013 | 11:57 PM
tosheto's Avatar
Front valve cover. On the passenger side corner. Take off your engine cover and inspect you valve cover for leaks really well.
Old Dec 9, 2013 | 03:47 AM
2damax's Avatar
Did you ever top off your oil and spill a little? The alternator is where the oil would go.
Old Dec 9, 2013 | 07:07 AM
03VQMAX's Avatar
Upper oil pan seals, it can fling oil in that area of its leaking...
Old Dec 15, 2013 | 05:49 AM
zig1ner's Avatar
It may be coming from the front valve cover or in install of the alternator who ever installed it could of cracked the timing cover
Old Dec 15, 2013 | 06:11 AM
koreanthunda's Avatar
If you replaced those other gaskets then it may be power steering fluid are you shure it's not red ?
Old Dec 16, 2013 | 03:46 PM
ramriv777's Avatar
Well, I'll be dipped in s#!t!! It is the p/s pump. I'd better get that replaced soon before it kills my alternator again!
Sent from my iPhone using MaximaOrg
Old Jan 18, 2014 | 10:22 AM
ramriv777's Avatar
Well Zig1ner, you were correct. It seems that the idiot mechanic that replaced my alternator either cracked the timing cover, or the silicone seal in that area. The leak is right on the upper alternator bracket. Now I have an uphill battle against Sears (I know, this is the last time I take my car to those monkeys with wrenches) to have them take responsibility for this. Wish me luck.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Cotozic
Jun 28, 2017 08:01 PM
rtirbany
Sep 8, 2015 11:46 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
acw
Aug 7, 2015 04:20 PM
