disassembled my gauge cluster and touched the fuel gauge needle...
Old Dec 16, 2013 | 06:06 AM
5 ltr. beater's Avatar
....and I didn't mark the position of the needle before I touched it. mind you I didn't remove ANY needles at all. I was just looking at how I can access the blue film on the back of the gauges without removing the needles. strange how the needles of the speedo,tach and temp all seem to be spring loaded inside and just return back to their normal position (0), but the fuel one can be moved to wherever you want .
so what happens now?
is our fuel gauge electrical and will the needle just return back to its position upon receiving a signal from the fuel level sender in the tank or do I need to recalibrate the gauge?
Old Dec 16, 2013 | 07:56 AM
Gemner's Avatar
I dont know the answer to your question, but IMO you should just go fill up the tank and then move the needle to full. If it has to be properly calibrated you will have just done that, and if it doesnt then everything should be ok either way.
Old Dec 16, 2013 | 09:29 AM
mikeBal's Avatar
^ as far as i know that is your best chance. More precisely would be if you could empty your tank, then you could rest the needle on the base.
Why are you trying to remove the blue film anyways? If you are wanting white or some other colors then leds are the way to go.
http://forums.maxima.org/5th-generat...one-works.html
That link is the best for LEDs for our gauges.
Old Dec 16, 2013 | 04:37 PM
Brudface's Avatar
I am pretty sure that there is a way to realign ALL your needles whether they're toasted or not running the diagnostic test within these postings will point you in the right direction. Run the test with your plastic piece off and align the needle as shown in the pictures.
https://maxima.org/showthread.php?t=664420&styleid=5
Old Dec 16, 2013 | 05:31 PM
Peter_03Max's Avatar
It should go back to normal once you plug everything back in. I removed the plastic cover to clean the inside and I was using the compressed air can to blow out the dust and dead bugs and the needles was swiping all over. Work fine once you power it up.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Garrettz459
Sep 28, 2015 02:50 PM
