2000 Infiniti I30 Transmission Issues. (Video)
Old Dec 25, 2013 | 08:11 PM
Cullen's Avatar
Hey guys the video will explain my issue, please watch.
Old Dec 25, 2013 | 11:00 PM
DennisMik's Avatar
What you probably have is a defective shift solenoid pack in side the transmission. There is a service bulletin on this. The bulletin number is NTB00-039D for the Maxima.The bulletin number for the Infiniti is different. The solenoid pack from a Nissan dealer is a $400 part, $310 from on-line places. There are after market solenoid packs that run around $130.
If you take it to a dealer, it will probably run around $800 or higher with labor and other miscellaneous parts.
Here is a link to the Maxima service bulletin:
http://maxima.theowensfamily.com/tsb/NTB00-039a.pdf
This is an older version of the service bulletin and the part number for the solenoids has changed. The current number is 31940-85X0B.
Found the service bulletin number for the Infiniti. It is ITB00-029B, dated Sept 25, 2001
Last edited by DennisMik; Dec 25, 2013 at 11:08 PM. Reason: added Infiniti bulletin number
Old Dec 25, 2013 | 11:40 PM
MaxMike93's Avatar
That's exactly what my 2000 I30 does! It gets better when the transmission is thoroughly warmed up, but it's still apparent. I've had mine for two and a half years and things haven't gotten much better or worse, by that I mean that it isn't like the transmission is about to fall apart. I'd like to get that bulletin done, but $800 is steep for a 13 year old car. I rarely, if ever, have to go WOT from a stop, but I found that letting off the gas and letting it shift, then getting back on the power after the RPMs drop makes things much smoother.
Mar 12, 2020 12:06 AM
RinconI30
Nov 10, 2015 10:55 PM
ballerchris510
Sep 11, 2015 05:29 PM
