Today: pre purchase inspection!
Old Jan 2, 2014 | 09:01 AM
Entrepit's Avatar
When ordering a pre purchase inspection on a 5.5 Gen., what should the mechanic be asked to look at in particular?
(I will be in okc, the car and shop will be in dallas.)
It has 134k miles, and is a '1 owner' 2003 GLE. I want to make sure that the points which matter to a maxima at this stage get checked out, and to really get the most out of my blind $100 investment.
Thank you and please respond ASAP!
Old Jan 2, 2014 | 09:05 AM
george__'s Avatar
Use search function man!
But here's a tiny list
- lower rad support
- electrical issues
- check engine oil level
Old Jan 2, 2014 | 10:49 AM
mclasser's Avatar
In the 5th gen most importantly:
-Seized calipers (particularly rears)
-Rust near fender wells
-Leaking struts/shredded dust boots
-Blue smoke from exhaust = oil-burner engine
-Rusted lower radiator support
-Wheel bearing hum/rumble
-All fluid conditions, especially brake + PS since these are most ignored
Old Jan 2, 2014 | 11:16 AM
Entrepit's Avatar
I'm searching, and so far I have:
Piston rings for oil burning problems
Wheel bearings
Lower radiator support
electrical issues
engine oil- see piston ring note above?
Interior rattles-
Bad Catalytic converter
Bad knock sensors
AC/Heater
MAF sensor
o2 sensors
Gears grinding
Bose radio's poop all the time
Cause Torque steer: Tranny code RS6FS1H means it has HLSD. that can be located under the hood on the firewall. if it says RS6FS1A then it's an open diff.
Hard shifts when cold, normal shifts when warmed up?
Stolen HID's, replaced with early 5th gen lights
LCA's by 150k
check the struts, that is another wear and tear item, you may see worn out shocks and springs.
Door hinges may have worn out too and most noticeable on the front doors.
Blitzfist: "Also cold start drive it and push it. take it for a highway run and floor it when merging. If it seems to hold up well, then the car is fine. Cold starting it is key though."
Wheelieking: "if there is a radiator leak then I'd watch out for a possible head gasket problem. Maybe someone can chime in on how to check it. That's a repair you don't want. The little problems you mentioned sound cheap to fix."
Scottwax: "Look at it in the full sun, makes spotting swirls, scratches, acid rain damage, water etching and evidence of repainting a lot easier. Repainting a trashed finish properly can easily cost more than replacing the engine."
What Dansmax said: Any service records? Have they replaced fluids, brakes, belts?
Did I mention oil burning??
Tookrzy...: check to see if the recalls about the camshaft position sensor is done
Denny 1986: Coilpacks cost an arm and a leg and its good if they're replaced with the upgraded version....(its a known problem with our cars) ... -> MAf = Mass Air Flow sensor..basically if this sensor fails, the car would hesitate to accelerate among other things.. -->
ScottWax: Drivetrain should be good to at least 200,000 miles assuming it was properly maintained. Expect that you might have to replace the precats with those miles.
Ask about camshaft position sensor.
LA02MAX: "5.0 gen: Solid car. The 01's have the updated MAF and coils so they generally don't have as many problems with those as the 00 maxima. My mom replaced her MAF and coils on her 00 with 01 parts at 60k miles and they lasted all the way to 240k. The only other thing she replaced on that car was the motor mounts. VERY reliable.
5.5 gen:
-A lot of people have 3rd gear synchro issues. The gear grinds a little going into third gear at higher RPMs. It doesn't affect the driveability (at least it didn't for me) but it's kind of annoying. I got it fixed under warranty.
-Some VQ35s are oil burners. We've basically isolated the issue to the piston rings, but the issue doesn't affect the majority of the cars out there (though the percentage affected is kind of uncomforting..).
The 5.5 gen is much more fun to drive than the 5.0, but some people like the smoothness of the VQ30 over the VQ35. The only thing I can advise is to do some high RPM shifts (>3k rpms) into third gear on a test drive, and also ask someone to rev the engine near redline and check if a decent amount of smoke comes out the exhaust. The smoke 'test' isn't definitive by any means but if you notice a large amount it might be an oil burner so you should ask them to monitor the oil level a couple thousand miles after you buy the car. If it burns oil, try to get it replaced under warranty.
My car has been pretty solid. I had the synchro issue and an o2 sensor go out on me, but the engine doesn't burn a drop of oil and it still runs very good at 67k."
Maximized2000: Referring to his problems -->"Coils, pads and rotors, MAF."
Nzelinsky:Test how the clutch feels and put it through all the gears. Make sure you pull it up over 4-5K rpms to see how it feels higher up in the revs. Look at the condition of the front tires too. If they are worn excessivley compared to the rear the owner probably bagged the car. Also bring a friend and have them rev up the car while you watch the exhaust, check for black or white smoke. (white = serious headgasket problem/ black = burning oil)... other than that just rip it around and put it through its paces, take some quick corners, hit the brakes hard and see the stopping power also. btw dont crash the car though! (http://forums.maxima.org/7212371-post535.html)
http://forums.maxima.org/7224151-post538.html --> "Ok I scoured the threads here...my eyes are burning from all the good information. So I have found the following things to look for as common problems on the Maxima's:
1. 02 sensors
2. converters
3. coils
4. blower motors
5. shocks
6. MAF
I am going to look at an 01 Se with 72k miles on it at a nissan dealer tomorrow. Have I missed anything above in my list? Also, they are offering a Nissan warranty for 2years and I want to see if any of the parts that are known problems would be covered. Can someone verify if my list is complete? If not what else should I be looking out for?"
In response --> Nothing from nobody.
http://forums.maxima.org/7342737-post567.html
"The story of my 2002 Maxima SE 78,000 miles : A Beautifully Wrapped Lemon
I bought it almost 3 yrs. ago to this day. About a month or so after my purchase I had to replace one of the ball bearings, then I had to replace the brakes, then roughly a year ago I took it to the dealership to have all the fluids flushed out and replaced (wasn't cheap), I also had a problem with my windows but it was a cheap fix $75. I have loved this car dearly up until this week. Apparently some 5th generation Maximas have an issure where the Pre-catalytic (sp?) converter regurgitates particles back into the engine roughing up the cylinder walls causing "blow-by." This ultimately ruins the engine. At 78,000 miles this is absolutely ridiculous and I am NEVER buying another Nissan. I do plan on contacting Nissan about this, I will post again to this thread with the results. The only thing that will reinstate my trust in Nissan is if they replace my engine on their dime."
--> 2slow responded: "Reviving this piece of the conversation.
I think homeyclause misunderstood the situation. The problem is not back pressure within the exhaust system, but rather the break-up of the pre-cat combined with exhaust flow reversion. The exhaust flow momentarily reverses (during valve overlap) which can draw pieces of a broken-up catalyst into the combustion chamber. Once inside the chamber these abrasives will damage the piston ring to cylinder wall seal and cause blow-by."
http://forums.maxima.org/7508493-post610.html
nightmareukl: you need to check 2 things in maxima, engine and tranny.
dip stick should be clean, if the is sludge any where, especially in the dips or all the way up top around the screws pass on the car it means oil change was not priority of previous owners. Tranny should shift without hesitation and be smooth especially when you accelerate had then let go of the gas, there should be no big bangs or jerks.
and most of all because you're not familiar with this car drive another one and make sure the one you want to buy is not lacking in power, because for someone who is not used to vq even when its not working properly will seems fine, been there
Jowo9: -Things to look for: hmm... the Bose CD player often starts cutting out on the left side... there's a write-up on here to fix that if you're good with taking things apart etc...or you can just replace it... or maybe you won't have that problem, or don't care. also, I've heard some 5.5 gens burn lots of oil, but I don't have that problem..
Wakeboard99: Based on the info I've found here I should check the following:
1. 02 sensors replaced?
2. converters replaced?
3. coils how many replaced?
4. blower motors working on 1-4
5. shocks replaced?
6. MAF replaced?
(+ knock sensor)
The6spdmax: Theres a common leak on the right top side of the radiator, you can't really see it unless from the side because its underneath the intake scoop (I don't know if thats the correct term). Is the coolant low?
Originally Posted by williswhatchyou View Post
will 8" speakers fit in the rear door pannels. I have an 03 w/o bose sytem
I have a 2003 se and the front doors take 6.5 inch speakers while the rears take 5.25 inch speakers. I got away with buying 4 alpine type r 6.5s and they fit fine. Watch out for the mounting depth if you get 6.5s. 4.75 to 5.3 mounting depth should fit. Most 6.75 inch speakers have too large of a mounting depth to fit the maxima without modification. 8 inch speakers will not fit, regardless of how large a spacer you buy, the door panel wouldn't go back on. If toy want some bass, add a sub.
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
09maxshawn11
Sep 30, 2015 10:28 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
