OBX Version 2 Headers O2 Sensor Relocation
Old Jan 2, 2014 | 06:43 PM
sfaber's Avatar
Since I had to plug the Rear Bung on OBX II Headers due to clearence near steering rack. I have an open Blue Sensor with 4 Wires (2 White 1 Gray 1 Black). I have Code P0037 due to this open sensor. I tried a Resistor between the 2 White wires but the code came back. Does anybody have a fix for this besides install another Bung port?
Old Jan 2, 2014 | 08:16 PM
TallTom's Avatar
Sounds like you need an o2 simulator (otherwise known as an o2 sim). do a search on here for more info on them.
Old Jan 2, 2014 | 09:17 PM
sfaber's Avatar
02 sim
I went to the site for the O2 SIM and explained my issue. And they suggested the Resistor only which I installed between the 2 white wires that did not work. They now suggest that I reconnect the Sensor and attach it to the car body. I will have to puchase a new sensor to try this since the other went to be recycled with the stock exhaust!
Old Jan 2, 2014 | 09:23 PM
george__'s Avatar
The front o2 sensors have to be plugged in (x2)
the rear o2 sensors need to be simulated or via anti-fouler method (x2) - install guide (http://forums.maxima.org/5th-generat...tallation.html)
Old Jan 3, 2014 | 07:35 AM
02whitemaximase's Avatar
I hope it is not a lite blue plug because your primary o2 NEEDS to be plugged in and in the stream. Just have a new bung welded 90 degrees toward the passenger side of the car. Problem easily solved.
my03maxima
Jul 28, 2024 07:40 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
