Bad 02 Sensor.
Old Jan 14, 2014 | 11:22 PM
grip1968's Avatar
Bad 02 Sensor.
I need to know were is my 02 sensor located on My 2000 maxima GLE, my SES light came on, The code is p0138 & p0139(bank 1 sensor 2), If anyone ever changed this sensor please let me know.
Old Jan 15, 2014 | 09:42 AM
DennisMik's Avatar
Depends on whether you have a fed spec or Cali spec.
On a Fed spec car, the sensor is located in the exhaust pipe after the main catalytic converter.
If the car is a Cali spec, it is in the y-pipe.
Old Jan 15, 2014 | 04:09 PM
grip1968's Avatar
Its fed spec...
Old Jan 16, 2014 | 07:26 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by grip1968
Its fed spec...
Then look at the diagram.
Old Jan 16, 2014 | 09:19 AM
grip1968's Avatar
I see were I need to change it. Now I need to know were to get a good one is the Bosch 02sensors any good, or should I stick with OEM. Do anybody know the part# for the Bosch sensor or OEM....
Old Jan 16, 2014 | 10:36 AM
Fizeau's Avatar
I changed both downsteam O2 sensors with "Bosch Premium Oxygen Sensor with OE SmartLink". Wire colors matched perfectly, no problem with fit. For $30 more you can get the same sensor with a plug.
Old Jan 16, 2014 | 10:39 AM
Fizeau's Avatar
Part No. 15727 at Advanced auto. The ones with a plug say Downstream Front and Rear.
Old Jan 16, 2014 | 12:49 PM
grip1968's Avatar
is this part#15727 for bank 1 sensor 2. that's the part# I need...
Old Jan 16, 2014 | 03:17 PM
DennisMik's Avatar
15727 is what you want. Sensor 2 is called a downstream sensor and that's what the 15727 part is. It is a universal sensor, meaning that you have to splice wires, so bank 1, bank 2, Cali spec, Fed spec have no meaning.
Personally, I'd go to rockauto.com and order the Bosch # 13969 sensor for $43.79. It has the correct Nissan plug on it so no splicing is needed.
http://www.rockauto.com/catalog/more...743&cc=1359222
Old Jan 16, 2014 | 03:45 PM
grip1968's Avatar
ok I went to advance auto they said I need two 02 sensor since im getting codes p0138 & p0139, is that true????
Old Jan 16, 2014 | 04:16 PM
NmexMAX's Avatar
dot dot dot ...
No, look at the diagram again. It's your rear sensor for bank #1.
138 = max voltage monitoring of sensor 2 from bank #1
139 = response monitoring of same sensor as above
Both codes mean that particular sensor is dead/dying.
Old Jan 16, 2014 | 04:28 PM
grip1968's Avatar
ok, got it I will order the Bosch # 13969 sensor, that should do the trick.
chisam14
Nov 6, 2018 08:56 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
RealityCheck
Oct 2, 2015 06:34 PM
Andy29
Sep 29, 2015 05:32 AM
zmcneely13
Sep 26, 2015 02:26 PM
