Right bank - Valve Assy-Solenoid, Valve Timing Control = 23796-EA20A
Left bank - Valve Assy-Solenoid, Valve Timing Control = 23796-EA20B
msrp $215, on-line $160
Bank 1, I'm assuming left side (steering wheel).Originally Posted by DennisMik
Right bank - Valve Assy-Solenoid, Valve Timing Control = 23796-EA20ALeft bank - Valve Assy-Solenoid, Valve Timing Control = 23796-EA20B
I heard our cars only have one.
http://www.courtesyparts.com/23731m-...-p-193702.html
It's cheaper from here....
Courtesyparts is OEM nissan parts right?
My car doesn't use two, only 1.
Dennis is correct, the you have 2 sensors, one for each bank. It states one part for each vehicle because the L and R are different sensors and are not interchangeable.
Both Scott and I are wrong in different ways. I gave the part numbers for the wrong parts.
left sensor - Camshaft Position Sensor - 23731-AL61A
right sensor - Camshaft Position Sensor - 23731-6J90B
Both are $77.42 @ nissanpartszone.com
http://www.nissanpartszone.com/Page_...mponentsNo=221
There are two camshaft position sensor
Both in the driver side.
Camshaft position sensor (bank 2) Near the radiator (sensor with angle female connector)
Camshaft position sensor (bank 1) Near the firewall (sensor with straight female connector)
To remove the connector, press down the green tab then pull the connector.
****...Originally Posted by colt149
There are two camshaft position sensorBoth in the driver side.
I think I bought bank 2, that's why the car isn't fixed.
I bought the one right by the air intake duct, seems to me like bank 2.
Is there anyway I can just replace the tab?Originally Posted by colt149
Try to check the error code
P0011: Camshaft Position Adavanced Timing Bank 1
P0021: Camshaft Position Advanced Timing Bank 2
See this link page:167
http://www.nicoclub.com/FSM/Maxima/2002/EC.pdf
ordered the female connector for the firewall....Originally Posted by colt149
Try to check the error codeP0011: Camshaft Position Adavanced Timing Bank 1
