HELP... Problem removing strut assembly
Old Feb 15, 2014 | 08:29 PM
Max_01_SE's Avatar
I removed strut assembly (strut and spring) on passenger side no problem, and replaced it with a quick strut.
However on driver side (I suspect strut assembly completely worn out), I removed all the bolts, however can't pull it out. It seems like the strut assembly expanded after I removed bottom bolt so that there is no clearance on top or bottom. I even tried pushing down on control arm for more clearance, but still not enough clearance.
Anyways is this common? Why would it happen? Didn't happen on passenger side, and all the videos I watched.
Old Feb 15, 2014 | 08:48 PM
Nopike's Avatar
Hopefully you have both front wheels jacked up at the same time. If you try doing this jacking one wheel up at a time you will have issues such as you describe.
Old Feb 15, 2014 | 09:04 PM
Max_01_SE's Avatar
Thanks for the reply.
Yes both wheels jacked up. Any other idea why?
Old Feb 15, 2014 | 09:06 PM
ACee's Avatar
Did you hit it with a small sledge?
Old Feb 15, 2014 | 09:21 PM
Nopike's Avatar
Is compressing the spring while it's still on the car an option?????? Without seeing it difficult to say.
Old Feb 15, 2014 | 09:24 PM
Max_01_SE's Avatar
I tried kicking the strut assembly inside to get it loose. Didn't use a hammer no.
You know, NORMALLY, when you remove last bolt strut assembly kinda DROPS and you have to catch it? Well mine didn't fall at all, it seems like it just expanded.
Is this even possible for strut assembly to expand (lengthen)?
Old Feb 15, 2014 | 09:25 PM
Max_01_SE's Avatar
That's what I'm thinking of doing tomorrow
Old Feb 15, 2014 | 09:26 PM
Nopike's Avatar
How about loosening the bottom bolts of the strut assembly you already installed. Or removing that Quickstrut all together. Then you may be able to remove the stuck strut.
Old Feb 15, 2014 | 09:29 PM
Nopike's Avatar
No I would not expect the strut assembly to lengthen. More likely the axle or swaybar assembly shifted on you so you do not have room. Removing the installed quick strut may help.
Old Feb 15, 2014 | 09:34 PM
Nopike's Avatar
Also make sure the new strut and spring assembly are the same size as the ones you removed. Possible you got the wrong size Quickstruts?
Old Feb 15, 2014 | 09:43 PM
Max_01_SE's Avatar
This is what happened then. Only explanation possible.
I'm guessing just play with brake rotor to shift it around?
Old Feb 15, 2014 | 09:49 PM
Max_01_SE's Avatar
No I think I was unclear. Passenger side removed old installed new, all good. Only driver side having problem removing old strut assembly.
Old Feb 15, 2014 | 09:53 PM
Nopike's Avatar
Yes you are right once you take the weight of the car off of the spring it will lengthen.
What I'm saying is remove the assembly you already installed and then try and remove the stuck one. The rotor and axle assembly does allow some maneuvering you could try that. Get a good nights sleep the answer will become clear in the morning.
Old Feb 15, 2014 | 10:01 PM
Max_01_SE's Avatar
Got it. I have to remove new quick strut anyways cuz I forgot to put old rubber isolator at the top of quick strut.
Thank you so much! Good night.
Old Feb 15, 2014 | 10:32 PM
Rods03Max619's Avatar
Good Luck...
Old Feb 16, 2014 | 04:37 AM
The_Fixer's Avatar
Both wheels have to be off the ground.be careful because i bet you are tearing up the axle boot with the bottom of the strut and also if your pushing the control arm down that far you may just pop your axle out.
Old Feb 16, 2014 | 06:16 AM
Nopike's Avatar
Make sure you are moving the brake rotor assembly toward the front of the vehicle and not toward the rear. +1 on the tearing of the boot. The struts should easily drop out like you stated earlier. You should not have to force anything. And do not use a hammer.
Old Feb 16, 2014 | 08:59 AM
Montego Murph's Avatar
I'll be doing my struts soon so I'm trying to pre-learn something here...
Should one remove both left and right, then install new left & right? (Instead of Remove & replace Left, then Remove & Replace right?)
Old Feb 16, 2014 | 09:16 AM
Nopike's Avatar
As long as you have both sides of the vehicle jacked up. The sequence should not matter. This is usually a pretty straightforward job.
Not sure why OP is having problems but we will find out in time. One more thing for the OP the upper spring mount has a small notch on it. That notch should face out toward the side of the vehicle.
Old Feb 16, 2014 | 01:20 PM
DjHackStyle's Avatar
If you have difficulty bringing ur control arm and sway bar down enough to give you the clearance you need then you need to unbolt the bottom strut bolts on the opposite side of the car, this will drop your sway bar and ur control arms will both drop giving u all the clearance you need.
Old Feb 17, 2014 | 05:31 AM
Max_01_SE's Avatar
are you the keymaster
Wish I had read this before.
I finally got the strut assembly out. The strut was so blow out that it fell apart as I was taking strut assembly out.
I pried out the strut assembly but popped out my axle in the process. Looking back, should have used spring compressor.
I had to change axle anyways (outer cv joint boot ripped) so not the end of the world. Just the problem of having to tow my car to the garage now.
At least the two quick struts are installed now lol.
Old Feb 17, 2014 | 06:29 AM
The_Fixer's Avatar
Sometimes you can get away with removing the end link too
Old Feb 17, 2014 | 11:25 AM
If theyre oem end links you will strip or break them. Safer to not touch them at all unless replacing aswell.
Old Feb 17, 2014 | 11:49 AM
njmaxseltd's Avatar
I've never heard of that happening before. So basically the piston extended completely out of the strut housing and the spring assembly fell off? That must have been a completely toasted strut. The force of the spring could have done some damage. Glad you got it out OK.
Old Mar 20, 2014 | 06:46 AM
vbnyc's Avatar
Hi.
I saw your thread about your installation of the quick struts.
What brand of quick struts did you install?
I was contemplating replacing mine with the Monroe quick struts, but some people have stated they're a bit too soft.
Which model Maxima did you install these on? Was it for a 2001 Maxima, as your name implies?
I have a 2000 MaximaSE and would prefer to save some money and replace the struts myself but don't want to deal with spring compression and other headaches associated with replacing just the strut itself.
Thanks in advance.
Btw, how has the ride been since replacing with the quick struts?
-vbnyc
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
