Easiest fuel pump/regulator check.
Old Feb 23, 2014 | 07:01 AM
car5car's Avatar
Run engine, turn it off, remove fuel pump fuse and start after 3-5 min.
If everything is OK, fuel system would still have pressure enough to start engine.
You can find out how bad regulator is. If engine doesn't start after 10-20 sec, it is bad.
Old Feb 23, 2014 | 10:30 AM
maxiiiboy's Avatar
Ok, let's say the engine does not start after 20 seconds.
What's the easiest way to decide whether it's the fuel pump or the regulator?
Old Feb 23, 2014 | 11:30 AM
4th gen maxi's Avatar
It will have enough pressure for a chug of fumes and some. That does not tell you much at all.
Its not direct Injection by any means after two revolutions of crank its pretty much depleted.
You check a regulator on a return fuel system by looking at your fuel trim and o2's
The days of carbs and single throttle body injection are long gone partna!
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
msellas
Sep 23, 2015 09:16 PM
