new day, new codes
Old Mar 17, 2014 | 02:13 PM
Stuart Ramsey's Avatar
new day, new codes
after driving my car to and from spring break, i got a new batch of codes from my check engine light and they are:
p0720.. ive seen discussions about this one on the forum already
p0011.. the guy at the auto parts place said that this meant the camshaft timing was over advanced. anyone want to explain this one?
and finally
p1574.. same guy said this was the ascd vehicle speed sensor.
anyone have any experience with these codes? please share any info.
Old Mar 17, 2014 | 03:58 PM
DennisMik's Avatar
P0011 - Bank 1 Intake Valve Timing (IVT) control performance - There is a gap between angle of target and phase-control angle degree. Possible causes are: Intake valve timing control solenoid valve, Harness or connectors, Crankshaft position sensor (POS), Camshaft position sensor (PHASE), Accumulation of debris to the signal pick-up portion of the camshaft
See page 165 in section EC of the Nissan service manual.
http://boredmder.com/FSMs/Nissan/Maxima/2002/EC.pdf
P0720 - The Transmission Control Module (TCM) is not receiving the pulse type signal from the revolution sensor in the automatic transmission. Possible causes are: revolution sensor or wire harness.
See page 116 in section AT of the Nissan service manual.
http://boredmder.com/FSMs/Nissan/Maxima/2002/AT.pdf
P1574 - ASCD vehicle speed sensor. The ECM detects a difference values between two vehicle speed signals if they are out of the specified range. Maybe this code will disappear when you fix the P0720 code.
See page 675 in section EC of the Nissan service manual.
Old Mar 17, 2014 | 05:13 PM
thanks for the info. went to rock auto and found an output speed sensor for $76 so ill be ordering that soon.
i also found a variable timing solenoid for $110, ill be getting it on my next paycheck hopefully. this is the right part, right?
Old Mar 17, 2014 | 10:44 PM
DennisMik's Avatar
If you ordered the Doorman part # 97611 for the speed sensor, that's the one.
For the valve timing solenoid, you need the bank 1 solenoid which is the right side of the engine.
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
