Quick question about sway bar bushings
Old Mar 18, 2014 | 02:41 AM
sinditdomo's Avatar
Do i order one or two of these?
Amazon.com: Moog K90587 Sway Bar Bushing: Automotive Amazon.com: Moog K90587 Sway Bar Bushing: Automotive
Old Mar 18, 2014 | 06:56 AM
TallTom's Avatar
One is what you need. But I would look into the Energy Suspension ones instead.
For GXE and GLE: http://www.energysuspensionparts.com...sp?prod=7.5124
for SE: http://www.energysuspensionparts.com...sp?prod=7.5125
Old Mar 18, 2014 | 08:15 AM
george__'s Avatar
Isn't ES supposedly "better"
Old Mar 18, 2014 | 08:21 AM
TallTom's Avatar
Yes.
NmexMAX's Avatar
dot dot dot ...
Stiffer maybe, better, that's subjective. In any case, if your car needs them, any replacement will be better.
Old Mar 18, 2014 | 08:25 AM
TallTom's Avatar
It's a sway bar. Less roll which is better.
Old Mar 18, 2014 | 08:44 AM
NmexMAX's Avatar
dot dot dot ...
It's an anti sway bar.
Old Mar 18, 2014 | 07:31 PM
sinditdomo's Avatar
Thanks ! I've researched a bunch in this forum and recall ES bushings being stiffer, Polyurethane material instead of OEM rubber ones, which gives the car a more firmer feel(with a slight increase in vibration). I know the ES ones last longer because of the material, but I'm just gonna get the rubber Moog ones because I hate vibration.
Old Mar 19, 2014 | 05:27 AM
djfrestyl's Avatar
Suspension Yoda
You will not experience ANY vibration WHATSOEVER with ES sway bar bushings bushings. Get them.
Old Mar 19, 2014 | 05:44 AM
Quickywd01's Avatar
Too much racecar, can't handle it...
Old Mar 19, 2014 | 08:35 AM
TallTom's Avatar
Werd. You won't feel vibrations at all with the sway bar bushings. You would if you used their motor mount/torque mount bushings.
Old Mar 19, 2014 | 08:48 AM
djfrestyl's Avatar
Suspension Yoda
Correct.
Old Mar 19, 2014 | 09:27 AM
tosheto's Avatar
I have the MOOG ones and I am happy with them, but the ES are probably better.
Old Mar 19, 2014 | 09:29 AM
djfrestyl's Avatar
Suspension Yoda
Yes, Moog are fine, but poly (ES) is better and are similarly priced. ES won't deteriorate like rubber would (both OEM and Moog are rubber).
lowpost99
Oct 26, 2025 06:53 PM
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
