Wheel spacers
Old Mar 18, 2014 | 02:14 PM
Bryso21's Avatar
Who has em!
Looking for :
-Brand
-Size
-Price
-Pictures if available
Looking to do my rear wheels either 20-25mm
Old Mar 19, 2014 | 09:40 AM
Prophecy99's Avatar
search! its out there so much you will be over whelmed.
Old Mar 19, 2014 | 10:39 AM
Rcrootbeer's Avatar
H&R has them. When looking, make sure you get ones that are hub centric with extended lugs.
Old Mar 19, 2014 | 11:29 AM
NmexMAX's Avatar
dot dot dot ...
That is all.
Old Mar 19, 2014 | 11:45 AM
ateick's Avatar
Had H&R front and rear. Excellent recommendation. Quality product. There are two versions - 1. longer studs. 2. Studs built into the spacer. You use existing studs to mount the spacer then you use the studs on the spacer to mount the wheel.
Option #2 is a lot less work and allows you to swap rims and remove spacers easily (for example if you are running winters for half the year.)
Old Mar 19, 2014 | 03:46 PM
NmexMAX's Avatar
dot dot dot ...
Keep in mind, option 2 has a fairly wide minimum thickness, and oftentimes, you need to trim your existing studs.
I use option 1 with 10 and 15 in rear on OEM 17 SE's.
Old Mar 19, 2014 | 06:27 PM
Maxterror's Avatar
this
this
Originally Posted by NmexMAX
That is all.
and that
Old Mar 20, 2014 | 01:41 PM
Bryso21's Avatar
Thank you for the heads up, still looking for pictures. I've done a search maybe I'm search retarded but I found one pic of a guy with rear spacers on a 2000 max and it was by fluke in a lowered thread.
20mm or 25mm for the rear wheels!?
I'm losing my mind thumb is hovering over the "buy now" button on the h&rs on eBay. Just what size is killin me.
Old Mar 20, 2014 | 02:45 PM
ateick's Avatar
I had 15mm front and 25mm rear with TE 17's lowered on Eibachs. Looked beautiful. Minor rub prob on one side of rears because that rear beam shifts once you lower it. 20mm is a safe bet.
Regarding my Option 2 above- the 17 TE rims have an opening in the back of the rim that allows for the stud should it be longer than the width of the spacer.
Now pull the trigger and buy some.
Old Mar 20, 2014 | 05:03 PM
Bryso21's Avatar
I had 15mm front and 25mm rear with TE 17's lowered on Eibachs. Looked beautiful. Minor rub prob on one side of rears because that rear beam shifts once you lower it. 20mm is a safe bet. Regarding my Option 2 above- the 17 TE rims have an opening in the back of the rim that allows for the stud should it be longer than the width of the spacer. Now pull the trigger and buy some.
Thanks, goin with the 20s! That's what I needed to hear
Old Mar 20, 2014 | 07:40 PM
george__'s Avatar
How does 20mm look with the stock 17" se rims lowered?
Old Mar 21, 2014 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/advanced-su...l-spacers.html
Old Mar 21, 2014 | 10:56 AM
TallTom's Avatar
The TDMi ones look like good pricing and some people on here like their products.
http://forums.maxima.org/general-max...l-spacers.html
Old Mar 21, 2014 | 01:32 PM
ateick's Avatar
Looks like a regular Maxima but with the wheels 20mm further out.
Old Mar 21, 2014 | 01:42 PM
ateick's Avatar
Before (not lowered):
After (not lowered):
After (lowered):
Old Mar 21, 2014 | 06:10 PM
george__'s Avatar
You have same color car as me. I LIKE.
Buying for next winter
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
