Question re. brake shims
Old Mar 21, 2014 | 11:04 AM
maxiiiboy's Avatar
I just replaced my front rotors and pads with a PowerStop pad & rotor set (bought a set of all four for ~ $150 from RockAuto.com). So far, I am very pleased with the result. The new set-up is smooth and quiet unlike my old Brembo blanks that exhibited extreme judder, especially at higher speeds; the runout on my old Brembos was an order of magnitude than the maximum runout specified by the FSM (0.07mm, or 0.028 in).
As I was doing the exchange I noticed that the my car only has a single pad shim rather than the dual set-up with a "shim" and "shim cover", as shown in the FSM. I guess the mechanic that installed my Brembo's (long time ago) decided to drop the shim cover, for whatever reason ....
So, here is my question: Is the shim cover required? Was the absence of the shim cover a major factor contributing to rotor damage (warping, thickness variation) ? Should I bother to get it and re-install?
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
Johnny9595
Sep 3, 2015 05:18 AM
