fog light relay problem. plz help!!
Old Mar 22, 2014 | 08:03 PM
e.esco's Avatar
What's going on guys? I need help with my fog lights. They do not turn on. I replaced bulbs and fuse and checked relay. When I put the tester on the top putting on the actual relay spot, the top prong does not have power but the one to the right of it does. And the other two are ground. Please help.
Old Mar 22, 2014 | 11:38 PM
DennisMik's Avatar
To start with, please do not post the same problem in more than 1 place.
What you found is sort of correct for when the fog lights are not on.
What kind of tester were you using? I don't know what you mean by top prong. Top is a subjective term.
Remove the relay and look on the bottom of it. There are tiny numbers next to the metal pins.
Pins 1 & 2 work as a pair and pins 3 & 5 work as another pair.
Pin 3 in the relay socket will have 12 volts all the time. This comes from the battery via fuse # 6 in the dash.
Pin # 5 sends the power from pin 3 to the fog lights. You could put a jumper in pins 3 and 5 and the fog lights should light up.
Pins 1 & 2 are used to make the relay work.
Pin # 1 will get 12 volts when the relay for the left hand headlight relay is energized, meaning the headlights are turned on.
Pin # 2 will then get a connection to ground from the fog light switch which energized the fog light relay which causes the for lights to light up.
See page 78 in the EL section of the Nissan FSM for the wiring diagram.
http://boredmder.com/FSMs/Nissan/Maxima/2003/EL.pdf
Old Mar 23, 2014 | 07:37 AM
e.esco's Avatar
No problem. Sorry about that. But the tester I was using was just to see if there is any ground or power.
Old Mar 23, 2014 | 05:56 PM
e.esco's Avatar
[QUOTE=DennisMik;8931484]To start with, please do not post the same problem in more than 1 place.
Thank you so much for your help it is greatly appreciated, I was able to get it too work thanks to your help.
Old Mar 24, 2014 | 09:49 AM
e.esco's Avatar
finished result.
Old Mar 24, 2014 | 10:51 AM
DennisMik's Avatar
Looks good! You did good.
Old Mar 24, 2014 | 10:56 AM
e.esco's Avatar
Thanks I really appreciate the help. Wouldn't have done it without it
Old Mar 24, 2014 | 11:16 AM
DennisMik's Avatar
You're welcome.
I think you would have done it by your self. Probably all I did was helped you do it a little faster.
Old Mar 24, 2014 | 02:00 PM
e.esco's Avatar
You're welcome.
agreed. it took me maybe 10 minutes lol.
Old Mar 24, 2014 | 02:02 PM
e.esco's Avatar
just because i'm curious, do all the 5.5's fog come on with just the side markers on?
Old Mar 24, 2014 | 10:59 PM
DennisMik's Avatar
It sounds like someone did a mod on your car. The way Nissan designed the circuitry, the power to energize the fog light relay comes from the headlight relay, meaning the headlights have to be turned on. Someone designed a mod to power the fog light relay from the tail light relay, which is where the side markers get their power from.
http://www.shiftice.com/fog_rewire.html
Old Mar 25, 2014 | 08:19 AM
e.esco's Avatar
thank you, someone must have done it before me.
matts95max
Apr 23, 2025 10:44 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
nbstriker10
Sep 4, 2015 04:26 PM
