transmission leaking
Old Apr 15, 2014 | 12:53 PM
nismo_nut's Avatar
So im driving home and I notice my transmission slipping the further I went the worse it got. It felt like I was ridding the clutch taking off and was over revving before it would shift. I get home, put it in park, then back to reverse then drive without acceleration and it would take a while to go into gear. I get out and its steadily dripping atf from the small hole at the bottom of the tranny. I thinking possibly torque converter seal? It is automatic
Old Apr 15, 2014 | 01:53 PM
george__'s Avatar
Did you check the ATF fluid dipstick to see what it said?
Hose clamps on there real tight? (on gen 5.5 there is a hose underneath the radiator <-- check it!!)
Old Apr 15, 2014 | 03:13 PM
ManualMaxima's Avatar
5th Gen till she dies!
Originally Posted by george__
^ Did you check the ATF fluid dipstick to see what it said? Hose clamps on there real tight? (on gen 5.5 there is a hose underneath the radiator <-- check it!!)
Now that's thinkin with your dipstick...
Old Apr 15, 2014 | 04:16 PM
nismo_nut's Avatar
Obviously I checked the dipstick. It was going empty. Due to it dripping out of the small hole in the bottom of the trans. Like I said in op.
Old Apr 15, 2014 | 04:19 PM
george__'s Avatar
Check the hoses and clamps. Clamp on the Maxima I drive went f000ko and yeah
Old Apr 15, 2014 | 04:26 PM
nismo_nut's Avatar
Wouldnt it be leaking out of a hose some where instead of the trans if it was a hose or clamp? Ive checked and whiped everything underneath and I see where its dripping from
Old Apr 15, 2014 | 06:01 PM
Don't listen to George btw, although I do find myself chuckling at his trolling often
Old Apr 15, 2014 | 07:18 PM
nismo_nut's Avatar
Guess the noobies gotta pay the troll toll lol
Old Apr 15, 2014 | 07:26 PM
chrome91's Avatar
not necessarily, it can leak where the cooler line meets the trans.
check the cooler lines to and from the radiator, the trans pan seal, where the dipstick tube goes into the trans, etc. its probably leaking from one of those places unless you ran over a solid object and punched a hole in the trans pan which to me is unlikely
Old Apr 15, 2014 | 08:09 PM
nismo_nut's Avatar
This is the hole im talking about. To the right of the drip. The drips from where it was leaking and running that far before it dripped.
Attached Thumbnails transmission leaking-received_m_mid_1397616882130_9cb0c263767a4bcb49_0.jpg
Old Apr 15, 2014 | 08:15 PM
chrome91's Avatar
no idea off the top of my head if that hole is even supposed to be there and if so why. what side of the trans is that hole on? bellhousing or tail?
Old Apr 15, 2014 | 08:22 PM
nismo_nut's Avatar
Im not forsure Ill jack it up an get another look tomorrow I just reached my phone underneath to snap the pic then zoomed in.
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
