Intake Valve Timing Control Solenoid Valve
Hello again everyone. I have a question about the intake valve timing control solenoid valve. Has anyone had any experience replacing this part and is there a process to follow. I had this code come up and according to tech notes they say just change the oil and clear the code. Just incase this does not work I and looking to find out if its just as simple as unbolting the part and replacing it or is there a process to follow so I don't mess anything up. thanks for all the help.
Disassemble VTC solenoids and clean with lots of brake cleaner or w/e. Merely spraying them out still in one piece isn't enough sometimes. Put power to them and make sure it's actuating, then you know it's still working.
I assume you have the timing over advanced code?
Yes, unbolt and clean. You can try to just spray it out without disassembling it. I used a lot of brake cleaner and let it soak for a while, too. I've had luck with that before, but it doesn't always work. I guess you can try it the easy way 1st.
I would clean both so you're not doing the other one later.
P0011
The engine (VQ35DE) have two camshaft sensor
P0011 (Camshaft Advanced Timing Bank 1)
p0021 (Camshaft Advanced Timing Bank 2)
Replace the two Camshaft Sensor
Both on the driver side
Both with rubber O ring
Both with green tab on the Connector ( to remove it PUSH down the green tab and pull the connector)
Camshaft Sensor Bank 2 (near the radiator with angle connector)
Camshaft Sensor Bank 1 (near the firewall with straight connector: need to remove the air filter assembly)
Replace the Crankshaft position sensor (below the engine in front of the radiator: Straight sensor without O ring
Replace it with oem parts.
See this link (page 167)
http://www.nicoclub.com/FSM/Maxima/2002/EC.pd
thanks
I hope cleaning this part will clear the code and also hope putting catalyst converters back on the car clears the smoke issue I have only driven the car 2 times without the cats on it both times I had smoke coming from the tail pipe. seems to me that they play a critical role for proper back pressure thus not allowing oil to pass thru valves. I had a 1982 Datsun 280zx that I put headers and no cats it smoked very little nothing like this maxima. I hope it didn't damage the engine
You need to install an oil catch can.
CorollaULEV
30
Aug 9, 2021 08:11 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
