wheel making noise when driving maxima 02
Old May 6, 2014 | 12:30 PM
bobozmc's Avatar
when driving my car which is a 02 maxima SE a noise sounding like two metals rubbing against each other so I'm not sure what it is, if its the bearing or the brakes, the noise becomes more intense the faster i go
Old May 6, 2014 | 12:37 PM
nissandrvr98's Avatar
check your rotors/pads. is it front or rear? driver or pass side?
does it go away when you brake?
Old May 6, 2014 | 12:41 PM
bobozmc's Avatar
its is the front passengers side
Old May 6, 2014 | 01:13 PM
cwholden72's Avatar
My 02 is doing the same thing. Does it sometimes when I turn as well.
Old May 6, 2014 | 01:14 PM
mazda626es's Avatar
Its possible the caliper is sticking and its constantly pressing the pads up against the rotor. Put the car up on a jack stand, put it in neutral and see how easy/hard it is to spin the tire. Also, check the rotor for signs of wear and the caliper boot as well. I had a similar issue with my rear passenger side maxima.
Old May 8, 2014 | 10:02 AM
yea, i've had rotors seize up before too-like mazda said, jack it up and pull. the wheel to see whats going on. pull the caliper and check that the piston is moving when the pedal is pressed.
Also, sometimes there are thin metal shims holding the pads in place-these sometimes warp and bend and make contact with moving parts.
I've also experienced the dust shield on the back of the rotor bending in and making contact in turns. easy to just bend away from rotor.
maxinout93
Oct 27, 2015 01:29 PM
egali045
Aug 16, 2015 01:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
