Swap radio for a Bose radio
Good day,
I have a maxima se 2002 ... original radio in it ...
I have access to the Bose Model CD Radio, amp and all speakers ....
Will it fit in the car with no problem ? Do i have to do a lot of mod to be abble to make it work
Stefan
Stefan
^Agree. The Bose is ok if it already came with the car. If you're going to do the work to swap you might as well get something with better features.
If you're intent on keeping installing the Bose it will fit but I think you'll have to redo the wiring.
The wire harnesses in the car are different for the Bose and non-Bose radios. It's a lot of work to either make your own wire harness or replace one.
Sell the Bose system and use the money on something else.
Thanks all
Good day
thank you all for your help ... will look for a new radio instead ...
Could you help me ... what is the maximum size for a double din can i take ... and also where to find a fiting to go around a double din that will fit perfect ...
Something that will follow rhe console design
The size of aftermarket double din radios have been standardized for years. It is just that many of the auto manufacturers design a non-standard radio in hopes that you will buy another one from the dealer.
That being the case, you need to get an adapter kit from a company such as METRA.
http://www.metraonline.com/vfg
HerpDerp1919
Sep 29, 2015 02:02 PM
