oil leak
Old May 31, 2014 | 08:55 PM
egali045's Avatar
oil leak
I have an oil leak dripping underneath my car but hard to see where it's dripping from. Does anyone know the possibilities of an oil leak??? Please help. thanks
Old May 31, 2014 | 09:00 PM
FallenOne's Avatar
Valve Cover Gaskets, Cam Position Sensor O-ring, Pan Gaskets. Check those and report back.
Old May 31, 2014 | 11:40 PM
chrome91's Avatar
valve cover gaskets, crank seal, oil pan, oil pressure sending unit, god knows what else. only way you can properly find out is wash the underside off, let it dry, then see where the oils coming from
Old Jun 1, 2014 | 08:42 PM
egali045's Avatar
I looked and took pictures of where the leaking is happening.
I can't tell what part it is where it's leaking from.
Also, Does the oil pan look normal?
Anything weird in the pictures that I should be concern of?
Old Jun 1, 2014 | 08:48 PM
egali045's Avatar
Old Jun 1, 2014 | 09:02 PM
chrome91's Avatar
oil pan looks fine to me but its hard to tell where the leak is, its a clusterbomb of oil. only proper way to tell as i said is wash it all off then look again after a bit and see where oil is coming from
also 4th pic from the bottom looks like maybe ATF leaking on the far left on the clamp unless its just the lighting
Old Jun 1, 2014 | 09:11 PM
egali045's Avatar
I was thinking the leak was coming from a screw(3nd from left, kinda middle) on the 2nd picture on top. But maybe your right , i do got to wash it first.
Also, what's atf ? Because their is oil on the flathead screw .
Old Jun 2, 2014 | 02:43 PM
cornholio's Avatar
ATF is automatic transmission fluid- can be a reddish or yellowish color. if this is your fluid and not actually motor oil it could be a sign of PS hose failing. that will leak down and cover much of that same area. easy way to check is see if PS fluid reservoir is low or poke the insulated hose and see if fluid comes out.
http://forums.maxima.org/5th-generat...hose-02-a.html
Old Jun 2, 2014 | 02:58 PM
ac max 92's Avatar
Looks like all that oil is caked on from wherever it's dripping down from. Do you have evidence of oil running down a specific side of the engine? i'd start by checking around the valve cover gaskets but i'd also look into what appears to be black gasket maker or silicone caked on behind the oil filter?
Old Jun 2, 2014 | 06:00 PM
ramriv777's Avatar
Oil cooler o-ring maybe?
Sent from my iPad using MaximaOrg
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
