p0455 & P0442
Old Jun 4, 2014 | 02:35 PM
egali045's Avatar
p0455 & P0442
Could be this be the reason why I have a vapor leak?
Anything weird in the pictures???
In the picture above, does that look like a leak??
Here's another picture that looks like weird,
Also.
is this weird or it's normal.
Old Jun 6, 2014 | 11:19 PM
mazda626es's Avatar
i can only see the middle picture, but a bad gas cap can lead to an evap leak. Or, the vent control valve is bad. I had the P0455, and i replaced the valve and cannister, I no longer get the check engine light.
Old Jun 7, 2014 | 05:48 AM
The_Fixer's Avatar
Its a internal leak its nothing you can see just replace your evap valve on the canister and your gas cap and make sure you plug the valve in till you hear it click
Old Jun 7, 2014 | 01:10 PM
egali045's Avatar
Is it easy to remove and install? I think it only has 2 screws
Old Jun 7, 2014 | 08:20 PM
cmd26's Avatar
The screws and canister might break is what I read when I had to do it and the canister cracked so I had to replace it anyway, if you try it be very careful.
Old Jun 8, 2014 | 01:46 PM
egali045's Avatar
Ok. So i would have to remove the canister so i can remove the valve or is it possible to remove the valve without having to remove the canister?
Old Jun 8, 2014 | 04:13 PM
The_Fixer's Avatar
Either way but easier to remove while thing and soak bolts in pb blaster
Old Jun 8, 2014 | 08:27 PM
cmd26's Avatar
You need to remove the canister it's basically 1 piece
Stason
Aug 19, 2015 11:35 PM
02maxima76
Jul 27, 2015 09:50 PM
egali045
Jul 23, 2015 07:10 PM
egali045
Jun 12, 2014 01:25 PM
egali045
May 24, 2014 01:42 PM
