Engine Light On (High Voltage)
I went to the Autozone like good half an hour ago to get it check out, the lady said it was reading high voltage.
I told her I just recently got a alternator replacement, and battery 2 weeks ago. It been fine no problems for 2 weeks until on my way back home from work on the highway Engine light came on.
I don't understand what made it came on now, not 2 weeks ago if voltage was reading high?
She told me drive for 100 miles it should go off but if doesn't then what should I do? Should I be concern or what?
P0132 is a O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor1). I think you're misconstruing it as a alternator issue. It could mean the sensor is shorted, or potential frayed wires for the sensor. You should clear the code first and see if it returns. If it does, check the wires for the sensor. If they are good, replace the sensor.
S
S
OBD code tells you. Possible cause you bought an aftermarket parts or the precat is clogged. You need to gut the two precat then use a nonfouler to the two secondary O2 sensor. OEM Genuine Nissan parts for 02 sensor is $150.00 at courtesyparts
Either way the first step is clear the code and see if it returns first. If it does, swap that O2 sensor with the one from the other bank. Clear codes and see if what comes up follows the sensor, or stays in the same place. If it follows, pretty sure it's the O2 sensor. If it stays, there is a wiring problem.
As for warranty on the o2 sensor, potentially, not sure what brand you ended up with, but you could always check with the place you bought it from.
S
Okay I managed it to fixed it there was just a loose wiring connections to the o2 sensor on (bank 1) and now the engine light on the dash is off.Thanks god!!
I think it was because from the music I was playing very loud cause vibrations make it loose? I mean I don't know what exactly can cause that.
The engine shakes and vibrates and this is probably what caused it.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
