6gen brake upgrade
What about the z16 pads that come with this kit? Im gonna be getting 04 kit correct?
That jerkoff that did my strut that day didn't even tighten the top bolts
Since you have a 5.5 all you need is Calipers, Pads and Rotors. The brake lines will fit and the calipers will bolt right up. Super easy swap.
Overkill in terms of actually needing to upgrade - not rotor size.
An inch larger diameter definitely makes a difference, but discounted by the front/rear brake ratio, I wonder if it makes that large of a difference.
All a matter of preference though.
Not only it the brake diameter increased from (5.5th Gen) 11.65" to 12.6" the rotor is thicker and acts as a better heatsink than the smaller compromised 02-03 (check out the inboard rotor face) it's missing at least an 1" to clear the larger 00-03 spindle versus 85-99 spindles!
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
