Turn only the fog light on?
Old Jun 27, 2014 | 05:24 PM
AT978's Avatar
I have seen over and over people have only their dogs on and I have not been able to figure out how to do it. I have read bits and pieces of how to do it but have not gathered enough info to clearly understand how to do it. Someone who has done it able to help? Thanks a lot, my ride is a stock AE
Old Jun 27, 2014 | 05:47 PM
asianstyle's Avatar
http://www.shiftice.com/fog_rewire.html
Old Jun 27, 2014 | 06:04 PM
AT978's Avatar
Will this still allow me to turn on my headlights whenever I want or does it mean that with this mod, I can only have either fogs or high beams on
Old Jun 27, 2014 | 06:26 PM
Amerikaner83's Avatar
Yes the fogs will work independent of the headlights, and the headlight operation is unchanged
Old Jun 27, 2014 | 07:24 PM
AT978's Avatar
Do I need to disconnect power or anything before I splice?
Old Jun 27, 2014 | 07:39 PM
bishop8520's Avatar
Although in this case since it is a small job, disconnecting the battery is not completely necessary, but you should always get into the habit of disconnecting it whenever electrical work takes place just as a precaution. Since you will NOT be working on the wire splicing with the headlights on, it should be ok in this case to forgo the disconnection of the battery.
Old Jun 27, 2014 | 08:30 PM
AT978's Avatar
If I splice the fog into the tail light wire, and the only way the tail light comes on is when it's in the park light position, how does that work?
Old Jun 27, 2014 | 09:56 PM
Double check your wiring.
Do you mean the brake lights no longer come on? You blew the brake light fuse...you need to change it out for one higher fuse. Example, 10A to 15A.
If you did this mod correctly, the fogs will turn on with the parking lights, and headlights.
Old Jun 27, 2014 | 10:06 PM
THIS ONE will let you do the fogs completely independent...so nothing but the fogs will be on if you so choose.
http://www.vqpower.com/v3/content/fo...n-maxima-00-01
^^ that will work on your AE
Old Jun 27, 2014 | 10:40 PM
AT978's Avatar
I haven't cut anything yet, I wanted more information before I actually did it.and also, I read this mod, will it mess with the ac at all?
Old Jun 27, 2014 | 10:52 PM
jjubert's Avatar
Just did this mod a couple of weeks ago...pretty str8 forward, and you can run the fogs independently of the parking lights. In my case it's pretty bright even to the point where running the fogs by themselves are extremely bright with the 6k HIDs....just follow the shiftice.com instructions and you'll be fine
Good luck with this mod, I love it so far!
Old Jun 27, 2014 | 11:05 PM
AT978's Avatar
Hmm I almost did it but as I was driving home from radio shack I was thinking, to have the tail lights on I need to turn the park lights on, and wiringing the fogs into the tail lights will mean that the park lights will come on also, right? If it doesn't, why?
Old Jun 28, 2014 | 12:11 AM
jjubert's Avatar
Ok, maybe i'm misunderstanding what you're trying to do but here I turned the parking light switch on with the fogs off:
Is this what you talking about?
Old Jun 28, 2014 | 12:50 AM
AT978's Avatar
Not really, we'll kinda, here, how do you turn the fogs on? Just the regular position? Can you show me what setting you have to have just the fogs? And which rewiring method did you use
Old Jun 28, 2014 | 09:07 AM
DennisMik's Avatar
Before you start doing anything, what year is you car?
The wire colors are not the same on all years, so if you follow a procedure for another year than what your car is, it won't work and could possibly cause short circuits.
Old Jun 28, 2014 | 11:07 AM
AT978's Avatar
Mine is the AE model 2001, I know I have to splice the yellow into the pink but it just doesn't make sense when I thought about the connection
Old Jun 28, 2014 | 11:46 AM
AT978's Avatar
Okay, it seems like my previous speculations were right, in this picture,http://www.shiftice.com/images/corporate/IMG_2574.jpg, which was the model car on the shiftice rewire mod, it looks like the park lights are on along with the fogs.
Old Jun 29, 2014 | 12:46 PM
Use the link I provided to get the fogs to work completely independent.
Old Jun 29, 2014 | 07:24 PM
AT978's Avatar
The ac cable is too short for me to get a good enough splice on it, what can I do?
Old Jun 29, 2014 | 10:10 PM
DennisMik's Avatar
Use another piece of wire as an extension.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
