Top Speed issues..?
Old Jul 8, 2014 | 10:07 PM
MaximaBennett's Avatar
Top Speed issues..?
My 03 Maxima has 275k miles on it, runs fine just won't exceed 105 mph. I've been told countless times they go 120-145 mph. What is the problem?
Old Jul 9, 2014 | 12:02 AM
dwapenyi's Avatar
03 Maxima GXE? Mostly likely CPU limited because of OEM tires speed rating.
Old Jul 9, 2014 | 02:26 AM
It's a 03 Maxima GLE
Old Jul 9, 2014 | 02:57 AM
dwapenyi's Avatar
You're right in that the car should easily go 145-150 mph with 255hp under the hood.....unrestricted CPU not withstanding.
Old Jul 9, 2014 | 05:27 AM
D.Stillwell's Avatar
I'm pretty sure they're drag limited around 143-145mph or so. My 5th gen gets to 145 before it hits the limiter, and 5.5gen body is basically the same so I think drag would be the same.
Now here is the key, IIRC only the SE models weren't limited, both the GXE & GLE were limited. Not sure if that was the same for the 5.5gen but I imagine probably so.
Old Jul 9, 2014 | 07:11 AM
Bronxboi5's Avatar
I thought drag limit was 153
Old Jul 9, 2014 | 07:15 AM
dwapenyi's Avatar
... IIRC only the SE models weren't limited, both the GXE & GLE were limited. Not sure if that was the same for the 5.5gen but I imagine probably so.
If the GXE and GLE were limited, that explains the OPs issue.
Old Jul 9, 2014 | 09:54 AM
NmexMAX's Avatar
dot dot dot ...
I'm sure you found this out ona dyno ..
02-03 AT's were/have been said to have a soft limiter in the late 120's.
My 03 AT with TS-Fspec at the top of 3rd gear @ 7100 RPM.
Old Jul 10, 2014 | 09:42 AM
colt149's Avatar
Top speed Issue
I[I] believe it is more of a safety issue
Wheels and Tires
GXE: 16" 5 spoke al-alloy wheels with 215/55HR16 tires
Overall height: 56.3 Turning diameter:35.4 ft
SE: 17" 6 spoke al-alloy wheels with P225/50VR17 performance tire
Overall height: 56.7 with sport tuned suspension, higher spring rate
thicker front stabilizer bar
Turning diameter:40.0
GLE: 17" 7 spoke al-alloy wheels with P215/55HR17
Overall height: 57.1 Turning diameter:40.00
[/I]
Old Jul 10, 2014 | 11:57 AM
NmexMAX's Avatar
dot dot dot ...
That's true in that many car makers wont allow the car to go above it's OEM tire rating.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
Sep 27, 2015 08:37 AM
