3rd brake light out
Old Jul 20, 2014 | 07:14 AM
Cb007's Avatar
3rd brake light out
I recently got my windows tinted. After the car was returned to me i got the "stop/tail"warning light. I figured it was only a coincidence and i'd get whichever bulb it was replaced once i got my brake job done the same weekend. Well after the brake job and new bulb the light went out again the next day. The the stop light fuses aren't blown and the bulb doesn't appear to be blown either. What is causing this and how do I fix it
Attached Thumbnails 3rd brake light out-0720141008-1-.jpg   3rd brake light out-0720141007-1-.jpg
Old Jul 20, 2014 | 03:42 PM
DennisMik's Avatar
The correct bulb typs is 7440. Is that what you are using?
Old Jul 20, 2014 | 04:02 PM
Cb007's Avatar
Yes
Old Jul 21, 2014 | 04:11 PM
DennisMik's Avatar
The bulb in the picture might be bad. Usually the filament goes straight across without any change in the straight line. Flick the bulb with your finger and see if it waves around, which would mean a bad bulb.
If the bulb is good but doesn't light up, you probably have a bad connection.
The window tint people probably took the brake light off and may have pulled on the wires too hard. Try wiggling/pulling/pushing on the wires going into the socket while someone is stepping on the brake pedal and see what happens.
Old Jul 22, 2014 | 07:52 PM
Cb007's Avatar
Parts store was out of the bulb i need so ill have to wait till tomorrow
Old Jul 23, 2014 | 04:08 PM
Cb007's Avatar
The wire that goes into the connector sees. I used electrical tape and changed the bulb(it did blow out)
Old Jul 23, 2014 | 06:52 PM
DennisMik's Avatar
I don't know what you mean by "The wire that goes into the connector sees."
But it sounds like you got it fixed. Yes?
Old Jul 23, 2014 | 07:20 PM
Cb007's Avatar
Oops the conector that goes to the bulb, one of those wires did seem loose. I had some one push on the brakes while i wiggled the wire and the bulb flickered.
Old Jul 23, 2014 | 07:51 PM
tosheto's Avatar
If it flickers that means that you found your problem. Fix the wire and you will be good to go.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
