02 Camshaft Positioning Sensor
Would a malfunctioning Camshaft Positioning Sensor cause my car to intermittently stall at idle and stumble at normal speeds?
Also, where is the #2 cylinder? Gotta change the coil pack on it. Thanks
I would say yes bc It did for me. It kept stalling. I had to change out both camshaft sensors. Cylinder 2 is in the front of the car first one on the left by the wiper fluid.
If you looking at the engine from the front of the car it goes:
1---3---5
2---4---6
1---3---5
2---4---6
Camshaft Position sensor
Read this
http://maxima.theowensfamily.com/tsb/NTB03-124.pdf
Ideally you need to replace both 1. camshaft sensor : one near the radiator
one near the firewall
2. crankshaft sensor
You need to replace it with OEM Genuine nissan parts at any dealership or
Courtesyparts.com or OEM aftermarket parts at Rockauto. Do not replace it with aftermarket parts of autozone, pepboys, ebay or online, it will erase the code but the problem will persist.
Which sensor is it? Do you have a code or just going by the stumbling.
FYI: I have a brand new, never installed, oem nissan cps for the rear side/ right side of the engine. The plug angles are different between them. $100 shipped.
thanks colt149
Read this
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
