Pending Codes P0300 and P0507
Old Aug 5, 2014 | 02:46 PM
Max2107's Avatar
No CEL, but got pending codes for P0300 (Random Misfire) and P0507 (IAC System RPM Higher Than Expected).
MAF and Throttle Body recently replaced.
Coils, plugs, dirty precat? Thoughts?
Old Aug 5, 2014 | 08:14 PM
maxiiiboy's Avatar
You got the right suspects.
The procedures for testing coils and spark plugs have been published on this forum. You should be able to search for them. I am not sure how to identify a clogged pre-cat; I would be looking for unusua/abnormal temperature.
Old Aug 6, 2014 | 02:24 PM
BigLou55's Avatar
did you perform an idle relearn after replacement?
Old Aug 6, 2014 | 04:29 PM
Max2107's Avatar
I attempted it a couple of times, but unsure if I did it correctly. I know it could be a factor.
Old Aug 6, 2014 | 07:45 PM
Ghost_54's Avatar
Throttle Body recently replaced, I would start here to make sure that there is no air leak as that would cause an irregular idle (also I sure hope that the throttle bodies butterfly was not touched or move by hand as they are very sensitive) resulting in the p0507 code ... The p0300 can also be a result of the above but it could also be caused by the VTS (variable timing solenoid) which has a very narrow passage way which you oil travels through and it can get clogged by dirt and other crap that may be in your oil crank case, this can take a few oil changes to resolve (if you do your own changes make sure you let the oil drain for as long as possible - an hour or more if possible - to get out as much from the bottom of the pan as possible) do this a few times to help clear the [possible clog of the VTS.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
