another y-pipe question
Old Jan 22, 2002 | 12:05 PM
Mr SoSa's Avatar
Is it legal to have a y-pipe installed in your car? Will you pass inspection? Does installing a y-pipe lower the life of your car's engine?
Old Jan 22, 2002 | 12:17 PM
Max_Vader_2K's Avatar
Wow, you sound just like me.
B4 I got my y-pipe I asked the same question.
Is it illegal- a little
will you pass the fart test- YES!!!! I did!!!
Dose it lower the life of the engine- I have no Idea and if it dose I will do an engine swap with a 2k2 Max!
Old Jan 22, 2002 | 12:37 PM
Mr SoSa's Avatar
Re: Wow, you sound just like me.
tahnk you so much for the reply... i appreciate it
Old Jan 22, 2002 | 12:44 PM
djmaxski's Avatar
It removes one of the pre-cats, which is only an emissions "issue" when the car is cold. If you warm it up well before an emissions test, you should have no problems passing, unless the inspection involves looking under the car and they see the label "Not for street use"...
Old Jan 22, 2002 | 03:23 PM
BlackAE's Avatar
Re: another y-pipe question
If the y-pipe gives more power, then the extra strain on the engine should reflect in a decreased life expectancy. How much is hard to say. In addition, the urge to push your car harder increases in proportion to the extra power, also leading to a decreased engine life. However, if you drink, smoke or eat junk food regularly you're probably decreasing your own life expectancy more than a y-pipe is decreasing your maxima's so I wouldn't worry too much about it. Party high 'cos pigs can't fly.
_______________________
y-pipe............................no y-pipe
Old Jan 22, 2002 | 10:37 PM
theMax's Avatar
Re: Re: another y-pipe question
A y doesn't make hp, it free's up hp by reducing the restrictions of the stock exhaust piping. I say it would be better for your car than the stock exhaust. It helps the car breath easier, but like you said, with a y you are more likley to beat on your car which would decrease the life expectancy. Don't worry just do your maintenance and you will be fine.
Old Jan 22, 2002 | 10:47 PM
RBa's Avatar
RBa
Re: Re: Re: another y-pipe question
I must have seen this question asked at least 30 times.... I must say when I asked it, a certain hitech feature called search wasn't available so with that in mind, Next time use the search function!!!..
Quickywd01
Sep 21, 2016 09:36 PM
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Socalstillen
Sep 26, 2015 12:01 PM
