O2 sensor heater resistor help
Old Aug 17, 2014 | 08:40 PM
GrannyShift's Avatar
Hello Im hoping to get some correct answers as to which resistor I use to eliminate p0037 and p0057. I can not seem to find a straight answer as to which resistor to use. Some say (2) 10ohm 10w and some say it doesnt work. Ive also seen 4ohm 50w, but i hope someone knows from experience. I have a 2003 maxima TE.
Thank you
Travis
Old Oct 5, 2014 | 03:13 PM
Horishima's Avatar
Thank you
Travis
second, I would also like to know.. stupid p0037 code
Old Oct 5, 2014 | 04:31 PM
colt149's Avatar
Oxygen sensor
OBD error code
p0037: H02S2 B1 : O2 sensor with white wire (Blue Connector)
P0057: H02S2 B2: O2 sensor with red white (green connector
This code are coming from your two secondary O2 Sensor. Dont fix the sensor.
Main problem: deteriorating precat or clogged precat not the sensor itself
Solution: Replace precat near the radiator and precat near the firewall
OEM Genuine precat will cost $599.00 each parts only while the OEM aftermarket parts (Bosal, Walker at Rockauto.com) will cost you $299.00.
Another option: install headers with O2 simulator.
The cheapest and will give some HP is to gut both precat (removal of honeycomb material inside then reinstall the precat) install 02 nonfouler to the two secondary 02 sensor.
Read this: http://www.energeticforum.com/renewa...n-foulers.html
my03maxima
Jul 28, 2024 07:40 AM
howardis
Dec 11, 2019 06:10 PM
knight_yyz
Nov 1, 2015 01:34 PM
