What is the best intake I can get for my 5.5 gen?
Old Aug 19, 2014 | 09:38 AM
Jor's Avatar
Jor
-Weapon-R
-JWT Pop Charger
-Stillin High Flow
-Other
I have a budget of like $200 but I want to make the right choice this time.
Old Aug 19, 2014 | 09:54 AM
Fakie J Farkerton's Avatar
I say pop charger.
Old Aug 19, 2014 | 09:58 AM
george__'s Avatar
Custom 4.5-5" one with a filter
Old Aug 19, 2014 | 10:12 AM
DOODOOCHIP's Avatar
Cold air with battery relocate. Run it behinde the fog light
Old Aug 19, 2014 | 05:19 PM
barristan's Avatar
GAB.
Save your $200 until you have $400 and get OBX headers.
Old Aug 20, 2014 | 03:54 AM
Jor's Avatar
Jor
Originally Posted by barristan
GAB.
I'd have to save$1900 to fix my oil leaks too.
http://www.rsaperformance.com/obxexh...zwUaAogR8P8HAQ
But let's say I did fix them, how hard are they to install?
Old Aug 20, 2014 | 04:32 AM
D.Stillwell's Avatar
IIRC, there are known fitment issues with these headers. And the other major part of the work will be getting the old nuts and bolts off the pre-cats and Ypipe.
Old Aug 20, 2014 | 04:35 AM
colt149's Avatar
JWT pop charger or Ghetto airbox drill 4 holes (1inch diameter on top of air filter holder). Use K& N filter. Headers if you can get a cattman, OBX have fitting issues. The cheapest way is to gut both precat, install a ypipe (warspeed or cattman)and 02 nonfouler to the two secondary O2 sensor.
Old Aug 20, 2014 | 10:53 AM
NmexMAX's Avatar
dot dot dot ...
This is just from my experience, which doesn't span very far.
The “best” intake for the budget enthusiast is a GAB. 9whp, proven by multiple members.
The “best” intake for those who do not want to hack their own stuff is the JWT POP, or some variation of a large area filter and velocity stack.
The “best” intake for those who don’t really care about spending time and money on their car is a 4” with a JWT style at the end of it. But as has been stated before, and is alos found in the sticky’s in the AM forum, requires larger injectors and no, not Z33 injectors, more like 440 or 550 injectors with a 4” intake of your choice. Doug’s, www.siliconeintakes.com coupled with the 100mm MAF housing from eBay. But no, that’s not it, if you spent the time to research, you wouldn’t be asking such question and would know that you also need a MAF scaler, again, it’s up to your pocket, but an AFC does well, coupled that with the fact that you also need a WB. The former also has to be familiar with the user before one actually begins using it, i.e, what settings should be used, and I mean set-up settings, the simple items, and then where the AFR should be where it shouldn’t be, etc.
I would leave links, but I’m not convinced you would actually read them.
Old Aug 20, 2014 | 11:22 AM
Jor's Avatar
Jor
I think what I want is some variation of the JWT Pop Charger, I just am not sure if I should buy the parts separately or just buy the pop charger by itself.
Old Aug 20, 2014 | 12:02 PM
NmexMAX's Avatar
dot dot dot ...
Filter is 35$, stack is 50$, and a MAF adapter I'd say in the 20-30$ range. In the end, you're getting a JWT POP Charger, that's plastic. Just get an actual JWT if you're in the mid-grade section above, it also comes with a bracket.
Old Aug 20, 2014 | 12:23 PM
Jor's Avatar
Jor
Yeah I think I'll just get a JWT so I can also get a heat shield.
http://www.ebay.com/itm/JWT-JIM-WOLF...p2054897.l4275
does this come with everything I need or just the filter and stack ,-,
Old Aug 20, 2014 | 02:17 PM
NmexMAX's Avatar
dot dot dot ...
That's everything you need.
IMO, a heat shield is not needed. Once you begin moving at say 20-25MPH or so, IAT's drop to a reasonable level. Couple that with the fact that this FWD VQ is just notorious for fairly annoying heat soak as are other Al IM VQ's.
What I just said in short, heat shields are overrated.
Old Aug 20, 2014 | 09:21 PM
a33_ridah's Avatar
Are there not many users with...say a BPi velocity stack coupled to a dryflow filter. Iv had them all in the past (GAB, jwt, injen lolz) What i have now is my favorite of all.
Its a 3 inch bpi stack and a 6 inch mouth aem dryflow. plenty other threads on others forums of the bpi vs blox/generic velocity stacks. Bpi FTW!
Old Aug 21, 2014 | 05:21 AM
I just got a velocity stack from JDM Sport in Cali and that AEM Dryflow 6" x 5" cone. I really like that setup. The BPi stacks are nylon, I prefer aluminum.
Old Aug 21, 2014 | 06:29 AM
Jor's Avatar
Jor
How much better is that than a jwt pop charger do you think?
http://www.ebay.com/itm/3-034-INLET-...p2054897.l4275
https://www.google.com/shopping/prod...ed=0CGIQpiswAA
What straight pipe would you recommend?
Old Aug 21, 2014 | 06:58 AM
NmexMAX's Avatar
dot dot dot ...
I had that, actually the 3.5" w/ LRMAF and now have the same thing but with a 4" stack/tubing/MAF housing, and by far this is my favorite.
I base my favorites off of numbers, and the JWT w/ 3" housing/tubing gave the best results. Didn't get quite the same #'s with the 3.5" BPi.
Haven't dyno'd the 4" yet though.
In any case, the decision isn't that hard and has been covered ten fold.
Old Aug 21, 2014 | 07:02 AM
^^ I don't think it's better than the JWT, just comes out to be way cheaper and I'm pretty sure it's not any worse than the JWT setup. The AEM dryflow filter is definitely better than whatever comes with the JWT package.
Advantage of JWT is that the stack itself is also the MAF adapter so you end up having a nice MAF adapter instead of having to buy one.
Velocity Stack + AEM Dryflow = roughly $60
JWT Popcharger = $100-150 depending on where you buy
^^ Also for the filter, you don't want the one in that link you posted. You want the AEM Part#21-209DBF for a velocity stack, it has a 6" inlet and is about 5-6" tall I think. It comes in red and grey colors:
http://www.aemintakes.com/search/pro...Prod=21-209DBF
Old Aug 21, 2014 | 07:26 AM
NmexMAX's Avatar
dot dot dot ...
Meh ... I was referring to HP numbers/results, not price #'s.
Old Aug 21, 2014 | 08:12 AM
The_Fixer's Avatar
you can always use the Planecrash method! dryer Duct and wire ties
Old Aug 21, 2014 | 08:49 AM
Jor's Avatar
Jor
I got bids on my injen, so it looks like it will be sold. I'm buying the jwt right now
Thanks everyone who helped, I probably would have ended up with something bad again haha
Old Aug 21, 2014 | 09:22 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
