PS Axle removal assitance
I'm in the process of removing the pass side axle and it seems to be seized in the carrier. Any suggestions for loosening. I have covered it now in PB and I have hammered on it with a large steel punch. Hasn't even budged and I have already broken off one of the 3 lobes on the axle that the 12mm bolts thread into.
I've used a wide screw driver to try and rotate the axle within the carrier bearing first to help break up any corrosion that locked it into place. Then I used a pry bar and worked it between the carrier bracket and one of the bolt lobes to try and build a gap. Heating up the carrier bracket might help too...but be very careful since you used a bit of PB blaster. It takes some coaxing to get it out and a bit of patience.
The other option is to remove the driver side axle (which is it's own bit of fun in itself, a well place pry bar will get it), and use something to hammer the passenger axle from the driver side.
S
S
I'm sure there's a name for it, but I'm going with bar.
I had someone tell me to do this on my girl's automatic and no go, but my LSD goes all the way through and a broom handle or something might have worked.
I never had much luck with PB. But soaking it in lube, torching it a bit (torches are always your friend) and using a pry bar or chisel to catch the edge and hammer it off works.
It was a *****, but I've done one before like that seized as all hell.
I used an air hammer in to carve out a gap. It has saved me many times. This is the one I have: http://www.harborfreight.com/air-imp...kit-92037.html
I know on 4th gens there is a bar keeping you from doing this unless you have LSD.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
